Buying 2016 Rebel - Hemi Tick and other Questions
G0S7
G0S7
TX
5.7 Eagle
Standby for idle video. I had the sales person take it for me. Just need to figure the best way to upload.
G0S7
G0S7
TX
5.7 Eagle
HERE SHE IS IDLING BOYS (cold start)! Of course the quality is low because he sent the vid through sms. Let me know your thoughts.
@Plankton is this sound pretty typical in your Rebel? From what I've seen on youtube the exhaust and lifter tick is much more pronounced. I would like to think I'm only hearing noisy injectors.
G0S7
G0S7
TX
5.7 Eagle
You know not every newer Ram has MDS. My buddy's 2015 BigHorn does not have it so may be your Rebel one either. To be 100% sure check the 8th digit of the vin. If it is D then no MDS. If it is 2 then your truck has MDS. My 2004 had hemi tick, the lifter were making noise at 35K, my 2018 is super quiet.
Thanks for that tip. I just checked and the 8th digit is a "T".
Plankton
Mid West
Fwiw, shooting the video down by the front wheel wells will give clearer audio of the lifters. Up top they tend to get drowned out by the fan and pulleys. I don't hear anything that isn't normal in that video though. Lots of folks with more knowledge than me here, so keep that in mind too. I'm fairly new to Rams/Hemi's.
kurek
Northwest
With due consideration for the quality of the video/audio I don't hear anything obviously out of sorts there. I have to admit the only Hemi I've really paid any close attention to in the real world is my own and it's a kitten so I haven't heard the lifter failure first hand but I've watched the same youtube videos you probably have about this and when they have the cam failure it sounds like an antique typewriter or something.
yourfloormat
Tucson, AZ
2009 TRX4
The ticking is usually broken manifold bolts. That can be remedied by machining the stock manifold or replacing them with headers.
I have a 2016 hemi CC and really like it!
honestly, Taco’s are great trucks too. Especially the gen before the current one. They are just a bit small for my needs.
Edit: redline oil is great for slowing down the tick as well
While the manifold has been a issue in the past its been somewhat remedied. The bigger issue thats been around for years and is known as the HEMI Tick is much worse. It involves the lifters. I myself just had the Tick. According to my mechanic he's only ever seen it on those with over 200k miles on it. Its a easy fix with new cam and non mds lifters prior to the issue arising.
yourfloormat
Tucson, AZ
2009 TRX4
That is no HEMI Tick. You may hear a small tick and that would be the exhaust manifold leaking. The HEMI Tick is very noticeable and you can hear it even with the hood closed while sitting in the drivers seat. Its a very pronounced tap tap tap
afwiest1211
6.7 cummins
Had a 2015 Ram sport loved the truck definitely had the tick but it was the exhaust manifold warranty repaired it but it was definitely there loved the truck other than that can’t beat a RAM would still have it but I upgraded to diesel definitely missed my bells and whistles so I had to do the tradesman to 8.4 ATC upgrade well worth the money spend MPGrimm at M2 mods definitely hooked me up and I am so excited
kurek
Northwest
Just for the hell of it I went out and recorded mine starting up, it's been sitting in the garage since Friday it's a detached garage and not heated so it's all ambient temperature, 30's at night and low 40's during the day for the last few days.
Funny thing is when I listen to the video everything sounds way louder than it seemed to me in person. I know part of that is the side exit exhaust blasts right into the wall and I'm inside the garage so everything is amplified but if I backed the truck out of the garage first then it wouldn't be a cold start.
Anyway here it is for your amusement:
HEMIMANN
Minneapolis, MN
2017 2500 Laramie Crew Cab
Your mechanic doesn't have enough user experience. If you search these sites, you will find non-MDS hemi engines also failed lifters and cams, and also way prior to 200k miles.
FCA changed lifter suppliers in 2017 MY. They knew about the issue, and made some attempt to alleviate or reduce it. This says to me there is a core design issue of some sort - design, materials, lubrication.
G0S7
G0S7
TX
5.7 Eagle
@kurek thank you so much for taking the time to post the vid. This is exactly what I was looking for yesterday. There was plenty of videos of people demonstrating exhaust leak sounds and the actual Hemi lifter tick, but I could not find anything showing how the engine is supposed to sound (normally), to compare mine to.
G0S7
G0S7
TX
5.7 Eagle
tacoma's are like trix, they for kids.
Hemi's are advanced ownership, but the juice is worth the squeeze.
I tend to agree, though I will always like the Tacoma my thoughts of it have changed a bit the past few days. For one I'm 6'3 and I had to come to the realization that taking the wife and two kids (one) in a booster seat on 8hr road trips is probably not going to be nearly enjoyable.., at all.
BTW to all, paper work will be signed today or tomorrow and I plan to go through with the deal. Looks like I'll be around here for on the forums for a while :waytogo:
tbird71
Lake Placid, FL
Tacos are good trucks, IF you dont make the same mistake I did and get a 2.7L 4 cyl...damn thing wouldnt get out of it's own way and forget about towing anything. What puzzles ME is why people buy a few yr old truck with 116K then wonder abt the tick and manifold bolts? They should KNOW that is all going to haqve to be addressed with those miles. Hell, the new ones with the rebates and negotiation aren't that much more...get some boxing gloves and go beat the hell out of the dealer! Your best chance to get a dealer to work with you is BEFORE you sign and take delivery....NOT after.
I'm 6'3 as well and my first 4x4 truck was a tacoma, actually loved it when I was 19. I couldn't even sit one at 56 years old, literally couldn't even sit it. I could not even imagine having a tacoma with two kids and a wife, lol. Just the sitting position of the tacoma is for young people. The Nissan sits a lot better for the midsixed, your knees are up like a chair, the tacoma is horrible.
Use high moly oil or lubegard biotech and keep that Cam protected.
red deer
Both 2012
Hemi 5.7 & Cummins 6.7
I own a 2012 outdoorsman with 255500km, I've done the manifold studs 3 times and a water pump.
I've owned it since new, never had any engine troubles at all. Tows our 5500lbs family camper all over alberta for the past 8 years religiously.
I run full synthetics front to back, diffs included.
G0S7
G0S7
TX
5.7 Eagle
Some people can turn their own wrenches and don't have to rely on a dealer warranty. Because of this, 100k miles is not a big deal to some of us. That doesn't mean I'm going neglectfully ignore common issues that have been reported from 2k miles all the way to 250k miles.
This thread was not created with the concern of manifold bolts. You may want to go back and actually read. I've already stated previously that I have no problem with replacing regular wear and tear components such as a water pump. Cam and lifter failure is the concern here. And I would be researching and gathering information on this issue rather the truck had 10miles or 200k miles on it. Anyone mechanically inclined, I would assume/think would do the same.
I have no clue what you're talking about in regards to working with the dealer before taking delivery. The truck needs nothing and I talked the price down from 27 to 25.5k if that's what you mean? No delivery has been taken yet. I made a deposit. ETA: If the idle video demonstrated a knocking or clacking engine then I would've completely walked away from the deal. Again you may want to actually read the thread.
G0S7
G0S7
TX
5.7 Eagle
That's great to hear, I'm actually researching shorty headers right now. I'm planning to run shorties so I can just leave the cats alone instead of altering the factory emissions systems. Figured I go ahead and knock that out of the way to avoid having to drill out a broken bolt in the future.
This thread does not concern manifold bolts. You may want to go back and actually read the thread. Cam and lifter failure is the concern here. And I would be researching and gathering information on this issue rather the truck had 10miles or 200k miles on it. Anyone mechanically inclined, I would assume/think would do the same.
I have no clue what you're talking about in regards to working with the dealer before taking delivery, you've lost me there. The truck needs nothing and I talked the price down from 27 to 25.5k if that's what you mean? No delivery has been taken yet. I made a deposit. Again you may want to actually read the thread.
The reason mani bolts is a concern in the same conversation is because mani bolts and lifter tick can sound the same with hemi's. There are two main hemi tick causes just fyi, but when testing the hemi you should obsrve how the engine sounds at warm idle, if there is any sewing machine sound, take a pass on it. The ticking on injectors is nothing but normal cadence, but that sewing machine sound is a bad deal. If you loved the deal and had sewing machine sound, you could dive into harder and see if it is mani or lifters, if it is mani bolts no problem, but only a darwin would buy a hemi with lifter tick.
ChloeBrooks
