Cabin Air Operation
tron67j
Maryland
You can turn recirculation on by pressing button, is that what you mean?
Princeton_Man
Princeton, WV
Like tron67j said, the recirculate/fresh air button on the front of your fan speed switch controls the recirc/fresh mechanism.
If you have your temperature control to the coolest setting it overides the recirc/fresh switch and places the system in recirc. Turning the temp control to the right one click removes the override.
J
Jesse Navarrette
Lovington, NM
6.7 cummins Diesel
No, It switch automatically to recycle when I do not what it to, looking for a way for the system to stay where I choose, either recycle or fresh outside air and not switch back to recycle when I have pushed the button to outside air. Ask the techs at a dodge dealership and all I got was the deer in the headlights look. And this gets back to what I have said for a few years
" If the computer does not them what parts to change, they are lost"
Octane
U S.A.
My '13 Ram does the same thing sometimes. It should stay in the setting I put it but it changes on its own for no particular reason
Even before I switched to the single zone Auto-Climate control I would notice the recirculation door would open/close by itself usually when it was hotter and high humidity. If you turn it to recirc then back open it should stay open till you turn the truck or HVAC off.
If either of the defrost vent modes are selected the recirc door doesn't close.
If you already have the 8.4 radio, doing the ATC mod is worth the price of admission. Probably my favorite mod I've done.
Outbreak
Cummins 6.7
Mine does the same thing and I HATE IT!!!
DevilDoc8404
S.C.
Crash68, what is the ATC mod?
Is there a fix for the recirculation door to stay closed? unless mine is on Max AC, it opens whenever it wants.
I do a lot of heavy city traffic, and the exhaust fumes just roll-on in
Automatic Temperature Control, you can add this feature if your truck is a single zone similar to what the dual zone trucks have.
Depending on what options your truck has will change what you need to add it. If you already have the 8.4 radio, you just need to add the temperature sensor and windshield humidity/dewpoint sensor.
There's times when you can't force the recirc closed
There is a possible answer
Fresh air enters from under the hood, then the air travels down through the the Cabin Air Filter.
Cabin Air Filter access door was first put in Rams built after January 2016, ( the filter was not included from the assembly plant )
My thought would be,
if you rather not have fresh air entering the cab
just make yourself a block off plate that will fit into the space where the CAF is inserted.
It would be easy if you had a 3D Printer ?
Personally, i press the
assblaster5000
Edmonton
5.7L
Do you think dropping a filter in would cause issues with hvac system?? Just found out mine has a door but no cabin air filter. Tech at dealership didn't know why. Suggested researching a little to avoid damaging something. I have a 2016 sxt.
Ram never had even a door for the Cabin Air Filter in December of 2015
In the early part of 2016, they installed the CAF Door
The Cabin Air Filter catches dirt, dust & pollen & that means that unwanted debris does not reach the Evaporator
this would not happen with a CAF installed
a CAF filter containing Charcoal helps to keep out odors & debris
some people prefer a Fram Fresh Breeze CAF
