CAI, tune and throttle body question...
shynola
hey all, getting the 14 model rcsb ready for the upcoming show season and am wanting a cool looking Cold Air Intake ($300-$400 range +/-). As i'm mentioning this to a friend today, he says that i'll also need a tune (if not immediately, then soon). I never EVER would of thought this to be the case but since it was brought up, now I absolutely have to know....i'm thinking the answer is no after reading CAI threads on here...but I wanted to ask our people in the "know".
Second is...I'm also gonna pick up one of the anodized throttle body covers from Moe's for a little dress-up as part of this build. So the question is, if/when I decide to up-size the throttle body in the future, will that same cover fit on an 85-87mm? Or should I expect the exterior dimensions of the housing to be different? A hemifever tune would be appropriate with the throttle body up-sizing too, at that time, wouldn't it?
thanks guys
HemiXpress
You don't necessarily need a tune for a CAI.
craigsez
Novascotia,Canada
Not a 100% sure but i think the ecu can to a degree make allowances for the extra lil bit of air from the cai..
WadXpress
HEMI
On moes throttle body I'm pretty sure it's factory outside so the cover will still fit.
You don't need a tuner but they make the truck way more fun to drive.
If you go with a vararam intake you can't really see the throttle body. S&B is the other popular intake
MADDOG
Living in a Firepit
6.4L HEMI
You don't need a tuner for a CAI but it will help manage the additional air in and adjust the air/fuel ratio some to optimize that.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
The guys are right on. A tuner is not needed for you to run an intake, but the tuner will show a much bigger performance gain than you will get from the intake.
And the throttle body cover will work on our ported throttle body as well because our units are just ported OEM Mopar units. You would just need to replace the double sided tape on the inside of the TB cover when you put it on the new ported unit.
shynola
shynola
thanks guys, I appreciate the input!
shynola
shynola
PM sent...and thanks!
Casper
U.S. Navy (Ret.)
Springfield, VA
5.7L
Did you decide on a CAI yet? Moe's offers both the Vararam which looks unique and gives best track performance and the S&B which looks better than factory stock when installed.
I like the S&B, but I'm no 1/4 miler.
shynola
shynola
thanks for the input. I like the S&B too. That's what i'm going to go with...with the scoop too. Matt said it didn't help much (if any), but the looks of it has me hooked and that's the name of the game here.
