Caltracs / Caltrac Part
3rdStrikePerformance
Sikeston, MO
Added all the Cal-Trac Traction Bars and associated parts. After going through their site and online catalog, there is nowhere on their site that shows the bushings, so I assume they are just some generic bushings they use. I will try to get a hold of them asap.
T
truckin151
2013 sport
They are aluminum eye bushings from what I read on Moes site.
Each of the two assemblies needed is comprised of three basic components:
1.Front Pivot
2.Force Transfer Link
3.Rear Mount
The combination of these components changes the pushing point on the car by redirecting the turning action (spring wrap-up) of the rear axle through the Force Transfer Link into the Front Pivot. The Front Pivot Spring Stop Bolt resists this turning motion and also controls the bending of the leaf spring at its thinnest section. The push into the Front Pivot helps the cars weight shift towards the rear of the car because of a new directed angle of force toward the front of the vehicle. (The "Instant Center" moves farther forward). This is where the system emulates a Four link system. The pinion angle is also maintained.
COMPONENT DESCRIPTION
1. The Front Pivot
Two steel plates sandwich the leaf spring sides. Two attach points in the plates provide the user with a selection in which the forward Force Transfer Link rod end can be located. A machined aluminum spring eye bushing and steel insert supports the front of the spring while allowing the plates to pivot. A spring stop bolt controls and restricts spring wrap-up. Spacers are provided for different vehicle applications that control clearances in the front spring eye pocket.
2. Force Transfer Link
This is a length of chromolly tubing with CNC machined threaded inserts TIG welded into each end. The front Insert is machined with right hand Threads and a HEX outer shape for Simple wrench adjustment of the Installed assembly. The rear insert is Left hand threaded. Opposite thread Styles at each end provide the means to easily lengthen or shorten the link for desired pre-load adjustment.
3. Rear Mount
A welded ¼" steel assembly replaces the original vehicles spring perch and incorporates the mounting provisions for the rear rod end of the Force Transfer Link.
GENERAL INSTALLATION GUIDE
Installing the CALTRACS is very straightforward. Raise and support the car high enough to remove the rear tires. Allow adequate working space. Next, the rear spring assemblies should be removed. This will facilitate replacement of the front eye bushings. Support the rear end housing in place while the springs are out. This will eliminate the need to disconnect the drive shaft, brake lines etc. Press or have pressed, the original front eye bushing out of each spring assembly. Replace these with the machined aluminum CALTRACS bushings supplied in the kit. Now, reinstall the rear springs into the car.
With each spring assembly ready to go in, position the forward pivot assembly to the front spring eye. (Assure that the Spring Stop Bolt is located on the upper surface of the spring.) Install the Steel Bushing through the pivot and front spring eye bushing. Now, reinstall the spring using the original hardware. Repeat the process for the other side.
Lower the rear axle assembly on to the springs. Install the supplied spring perches as you would the stock items being replaced. Attach the shocks.
Now the Force Transfer Link can be installed by starting the HEX (wrenching) end on to the forward rod end. Remove the rear rod end from the spring perch and start its threads into the rear Force Transfer Link. Adjust the assembly to proper length by holding the rear rod end then rotating the Force Transfer Link until the rear rod end will line up with the mounting hole in the rear spring perch. Install the rear rod end fastener and secure.
With the CALTRACS installed and the rear tires reinstalled, lower the car to the ground and put the drivers weight in the car be sure there is no pre-load on the bars. As an initial setting, turn the Force Transfer Link until the spring Stop Bolt just contacts the upper surface of the spring, then turn the Force Transfer Link one quarter turn more to establish pre-load. Tighten the Force Transfer Link lock nut. That's it!
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
The bushibgs you are talking about are the one that go into the front eye of the vehicle spring. When the Caltracs are removed no one wants to remove the bushing, so used kits usually don't come with the bushing.
This is the rear mount used on a flip kit version.
I don't have a picture of the front pivot, but they are the same on both versions.
Fat Jack
Chattanooga, Tn
V-10 505ci
Cal-Tracs are the best mod I have done to my truck. Makes a hell of a difference at the track and on the street.
Sikeston, MO
$40 for the bushings. They don't discount those...??
Anyway, I am going to offer you guys a deal here....
Caltrac Traction bars for $350 shipped. I have to have 3 purchases at this price to make the deal, so come on guys, jump on this. Lowest price you will find anywhere!
Redtruck-VA
Virginia
If you have wheel hop this is the cure. I highly rcommend them, they are simple and effective means to control the axle.
T
truckin151
2013 sport
Is that $40 for the set or $40 per bushing?
OklaHemi
new age hemi
duane do you have any insight on the lakewood traction bars? do they run as well as the caltracs? thats a pretty big price difference
OklaHemi
new age hemi
all right. thanks
Sikeston, MO
No sir, they are no where near as good as the cal tracs, but for the money, they are a good buy. I need the money by the end of the month guys if any of you are interested in these.
Sikeston, MO
Well I guess you guys missed out on this deal..:sad72:..I have ordered the 3 sets needed to be a vendor with them, but if you guys want them now, they will be normal price..unfortunately. Believe me, this was one heck of a bargain..:secret:..bought a set for my own truck!
Sikeston, MO
Got my Cal-tracs in today! I will be installing them within the next week, so look for an installation write up! :superhack:
T
truckin151
2013 sport
Damn, I had completely put this mod off, had other financial issues that needed to be taken care of the last month. Damn!!
Well I am going to be ordering some new parts here in a bit, Looking at doing the caltracs, Vararam and efan here shortly. Caltracs and efan hopefully end of the month and vararam soon after that. Want a two stage fan though, one with a high and low setting that I can run a switch into the cab to manually toggle it. Sitting in traffic when its 110*+ out makes the temps climbe fast so on those days I'd much rather be able to hit the switch for a high setting when needed.
Sikeston, MO
Best bet is to get a 183 e-fan, and instead of using the thermostat controller, use a 3 way switch. Simply install a resistor in one line so the fan doesn't run as fast. Just be careful not to go too low....
T
truckin151
2013 sport
Pretty sure there are a few two speed fans out there that would only require a high/low switch and flow the right amount of cfm. I don't want an off switch as I want it to run even after the truck is turned off and would hate to forgetor bump the switch off.
