Cam/Lifters Update
CunningStunt
Abbeville, AL
5.7L Hemi 4X4 Crew White/Chrome
I got the cam, lifters, timing set, and head gaskets installed. Putting heads on and hopefully rocker assemblies/pushrods this afternoon.
A couple questions:
-Harmonic balancer...what's the "proper" procedure for installing the balancer back on the crank?
-Best RTV to use for timing cover/oil pan surface
-What's the break in process, oil/filters, quantity of oil changes and at what increments before she is ready to be driven on the regular?
-While installing the cam, I got some assembly lube on the camshaft bolt while using it for leverage to install the cam. Should I try to clean that off and blow out the camshaft bolt hole before torqueing to spec?
DILLIGAF
Canada
Use the old balancer bolt to set it back into place. I just used my 1/2 Milwaukee impact...lol...
Im a big fan of Victor Reinz REINZOSIL RTV.
As for break-in, everyone has a different opinion. Since its just a cam swap I didn't bother. and did an oil change at 1000km.
CunningStunt
CunningStunt
Abbeville, AL
I started getting heads ready to go onto the block and when putting the passenger side spark plugs in the head, I stripped 2 holes! I have the special tool and all! I went counterclockwise till i felt the thread and then started and in both holes that stripped, I got a quarter of the way in before binding. Taking it into the machine shop in the AM to retap...B.S.
The driver's side plugs threaded in without issue so I removed one from each cylinder (So I can turn the crank to check rocker/pushrods are seated correctly), and got the heads, rocker arms, and pushrods installed and seated. All went well on the driver's side. I was so flippin' pi553d though when threading those plugs in man...really threw a wrench in my spokes as I had a vision of having heads on today and starting with the rest of the peripherals friday for hopefully running this weekend...
RamRod37
2014 Ram 2500 HD 5.7 Hemi
Georgetown TN
At least you did not do what I did when I done mine got the heads all back on ready to put pushrods in then realized once I could not find the bottom setting in my pushrods omg I forgot to put the dang new lifters in that was a hour to redo yeah was not happy with myself for that but she now has over 9k miles since
CunningStunt
CunningStunt
Abbeville, AL
Dang! Did you torque the heads and did the pushrods fall into the oil pan before you realized? lol
RamRod37
Georgetown TN
yeah heads was torqued done and no over time I have made it a habit to not let go of push rod till I know it seated that was the problem there was nothing there so could not let go then it was like someone hit me up side the head DUH lifters still on table. its funny now but still ticks me off I did it
Don't worry you're not the only one who's had a brain fart while working on something,lol :rolleyes: :Big Laugh:
CunningStunt
CunningStunt
Abbeville, AL
Should I heat the harmonic balancer or will an impact have enough force to drive it on without binding it?
Crooks1130
Louisiana
You raw-dawg it or should I apply some spit?
I’ve done it by hand and torqued to spec before and have also don’t the impact and called it good, never seen an issue with either. No Lube, raw dog it in there. Use the old one to push it in and seat it, then swap it out for your new one and torque it down.
Crooks1130
Louisiana
If you do it by hand, just find a way to jam it from turning and it goes on pretty east
CunningStunt
CunningStunt
Abbeville, AL
Right on man, thanks. I am reusing crankshaft bolt so ill just torque it. Thanks!
CunningStunt
CunningStunt
Abbeville, AL
Ok Cur
ok wondering how things went did you get her back together yet
Duuuuude!!! I am so close! I got everything in except fan/clutch and shroud and upper radiator hose, and I need to bolt the passenger side exhaust to downpipe. I will be cranking her up this afternoon, come hell or high water. BTW, **** the engineer that put the o2 sensor in the way of the bolt head on the drivers side.
RamRod37
Georgetown TN
good deal yeah that is the normal with about all now gm is bad at it too have to remove the O2 to get the bolts glad you about got it
Goodie1990
