Redtruck-VA
- Jun 29, 2010
- 5,864
- 985
- Location
- Virginia
- 2003 & 1989 D250 RWD
- Hemi-5.7, 5.9 12v & 24v diesel
Over the years I have mentioned the Split Second Cam Tuner
http://www.moes-performance.com/SearchResults.asp?Search=Cam+Tuner
Suggesting it could help with managing some cam installs in a 03. I have used the Split Second PSC1-003 with good results and expect similar results from the "Cam Tuner" but have never actually tried one. So I've ordered one from Moe's to see how it performs. I just recently went back to stock PCM tune using SC3865 (91) with a Crazy Spartan 112lsa and it would not idle. Installed my "High Idle mod and it idles good at 800 rpm cold and is settling to 650-700rpm warm. This is slightly higher than it was before when I ran this configuration with the difference of a power wire which I do not have installed. I'll post up results when I install the Cam Tuner.
