Can I not install tow hooks?
ClassicJoe
NC
After installing the level last night, I was looking under the truck at where the tow hooks are supposed to be installed. I noticed that it looks different than my neighbor's setup. Mine does not have the bracket that hold the hooks about half way down. Is the 2019 Classic not setup to accept tow hooks, or just a different install/hook?
Ricks Ram
The Tow Hooks should come with the brackets to install them.e591eb97a4ee8c36da77209fee2f5e87.jpg
Sent from my SM-G981U1 using Tapatalk
kurek
Northwest
Mine came with the brackets, and also I bought the blackout panels that were cut for the hooks.. I guess I could have saved $20 and cut the panels I already had or like some people just don't reinstall the panels at all.
Moot point later when I replaced the whole bumper :D
chris52010trx4
ontario
I just did mine and you'll be good... main bolt goes off the frame mount and ull have 2 18mm to bolt to the front where you see the 3 nuts.7f58eeee5ecd43d3f34ab72511554cc9.jpg042ef8d74e899abfddb30a047ed4e6ab.jpg
Sent from my SM-G965W using Tapatalk
ClassicJoe
ClassicJoe
NC
Forgive me, but I do not understand where, or what, it bolts to near the piece with the three nuts.
ClassicJoe
ClassicJoe
NC
Disregard... It appears as though you just remove the two bottom nuts and install them back over the bracket...
kurek
Northwest
No experience with that website, but that's a bargain.
kurek
Northwest
I'm guessing the website is fine but the hooks are almost definitely reproduction (not OEM) - well part of it is in the way it's worded "replace on OEM.."
The price there isn't too different from Amazon - where they claim to be a reproduction as well.
chris52010trx4
ontario
I've read that sometimes they ship the wrong second bracket on aftermarket ones, also the price difference oem vs aftermarket was like 15 bucks in Canada... I paid 200 shipped to the door for 2 hooks and the larger bolts that go to the bottom frame mount. Put them to work a week after yanking out my plow truck after I over extended the plow and hooked it on some really packed snow. They worked great [emoji106]
Toddbigboytruck
Ontario
Where did you get your hooks I have a 18 Laramie. And I want hooks
chris52010trx4
ontario
Motor city chrysler in Windsor Canada... they have a parts site that i ordered from..you will have to cut the insert yourself
Toddbigboytruck
Ontario
I have to look into it next time I am in Windsor May I ask how much they cost. I was looking into getting them from wrecker
chris52010trx4
ontario
There's 2 ways to buy... 1 part number for the 2 hooks as a kit or else buy them separately per part number as I did... its about 20 bucks cheaper that way after I looked into it. Part numbers and cost in pic below
Ram 4th Gen 1500 hooks
The heavy duty tows hooks are quite different & there is more to them than what is in this image
