Can't get old CV joint out, ciezed? 2011 1500 4x4 PLEASE HELP!!
MADDOG
Living in a Firepit
6.4L HEMI
Which CV joint are you trying to remove?
Oh, and Welcome to the forum!
charonblk07
Calgary, Ab
F1-A forged 349ci
Front axle CV requires a bigger hammer and just start beating the **** out o' it. When you reinstall just add some anti-seize to the splines and you'll never have an issue again.
pickupman66
Tennessee
Geting ti started off the splines is tough. I used a screwdriver to wedge in there to get it broke loose.
dunney
Hey, kids, just latching on to an old thread again....
Trying to replace the passenger CV axle, and I just want to make sure I'm not missing anything. The tire/rim are obviously off, as are the caliper and rotor. I got the 36mm nut off using Autozone's socket. Is there anything else? It doesn't look like there is enough room. Please advise, mine is also a 2011 1500 4X4 5.7.
