Cargo Camera Grid lines off
Plainbroke
Kansas
Is there a place in AlphOBD to turn OFF grid lines on Cargo Camera or that something that is built into my after market camera?
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Typically a hardware switch or dipswitch on the aftermarket camera. Good ones can also flip/mirror the image with the switches.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
grid lines on a 3rd brake light/cargo camera ?
i did not know that there was such a thing
I just have the grid lines on my tailgate handle camera
CanRebel
Toronto
He has an after market camera, not factory.
As it as mentioned above. it's generally setting on camera itself. switch and/or setting.
If there are no docs for it. Use google, see if there is anything you can find. very cheap ones, usually don't allow you to do anything.
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
The only thing I can add is on some aftermarket cameras I've seen a small thin wire that if you cut it the lines are off.
Post the link of the camera you bought so we can see what you're working with.
I have a stock "Cargo Camera" on the 3rd brake light and there are no lines. The rear backup camera in the tailgate does.
