JAMMAN
- Nov 17, 2014
- 349
- 75
- 2002
- 4.7
Today I put some bigger tires on, a year ago or so I did a poor mans front lift, cranking torsion bars and gained about 1 and 1/2 inches in the front.
Had it aligned, they said there is no way to adjust the caster/camber because I needed "cam bolts" which I probably should have installed when I did the upper arms/ lower ball joints. It was close to dead equal on both sides and wasn't far enough out to cause major concern but it still bugs me, like an OCD thing you can't feel it but know it is there.
Has anyone else installed these "cam bolts" and do they work right, is there several different kinds I should avoid? Thanks- Jim
