- Joined
- Jan 17, 2016
- Posts
- 23,732
- Reaction score
- 54,519
- Ram Year
- 14 Sport
- Engine
- 5.7
Just stumbled across this over on High Performance Rams,about using this pcv replacement to run a catch can on a 6.4 intake manifold.
www.builditmotorsport.com
the part is this. You just have to buy a in line one way valve. And whatever size hoses you have on your catch can needs to be 3/8” going into this part. You just swap your O rings for your old pic valve to this one. https://www.builditmotorsport.com/...
Hemi Positive Crankcase Ventilation (PCV) Reroute
Designed specifically for 2003–2008 5.7L Hemi Ram truck factory intake manifolds and All 6.4L Hemi Ram truck factory intake manifolds, this PCV Reroute makes it easy to properly install and route an oil catch can system. Because the factory PCV system on these intake manifolds is self-contained...
