Change coil spring or add airlift on ram 1500
06max
Quebec
Hello,
I have a ram 1500 2017. I bought a 6500lbs travel trailer. I don't want too much sag on the back of my truck. I wonder if I would be better to change my coils springs for more HD (tufftruck 1223v) because I will only tow a few times a year, or if I install a kit like the airlift loadlifter 5000 that I will inflate when I need it. What do you think is the best option?
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
Id so the Airlift, we use them at work with great success.
welcome to the forum!
DILLIGAF
Canadian Forces
Canada
Timbrens
chrisbh17
Im in somewhat the same situation.....rarely (if ever) will tow with my truck, but I would like more support when I get loads of mulch, dirt, etc.
I like the airbag idea because I could tailor it just right, but I like the spring idea because they are pretty much foolproof.
68PowerWagon
Dayton, Ohio
2022 Laramie 3500
6.7 CTD
For you I would suggest the air bags. Not very expensive & easy to install. When you don't need them you just keep the pressure low so it doesn't ride rough.
mtofell
As others have said, WDH and airbags are not a substitute for one another. They work together nicely. For bags I say don't skimp with cheap ones. I've run several sets of Firestone 5000 on HD trucks and love them. Timbrens would word too but aren't as versatile.
Ktstull
HEMI 5.7
Airlift makes a bag that goes into the coil spring to help stiffen the spring. I use that in combination with a WD hitch to get a very nice ride and level set up out of my 2015 1500 when pulling a travel trailer that’s almost 9500#s.
jawzs2
Air Force
South Jersey
I'm in the opposite camp, I put the springs on mine, touched it once and forgot about it. Just use my air pressure gauge for the tires.
chrisbh17
Thats what I was leaning towards.....originally wanted Timber Groves, but hoses can leak, rubber can break down, etc.
Springs are pretty much forever.
Ktstull
HEMI 5.7
How was your ride quality after that? I like my super smooth quality with the stock springs, I’m afraid if I change them to a stiffer one, it’ll be a stiffer ride.
jawzs2
Air Force
South Jersey
I put on the 1223V's and couldn't tell the difference. and neither could my wife or mother-in-law, it still rode great
sam darakjy
wilmington nc
2018 Tradesman Crew Cab 4x4
Timbrens on my 2500. Almost 3000 lbs payload and sits and rides great.
WRX03
Roanoke
V8
I did the Timbergrove bags because they weren't too difficult to install at all. Put the schrader valve next to the license plate. For the rare heavy hauling they do the job.
M4245
Phila. Pa.
2017 Laramie +2019 classic B.H.
Both 5.7
I would use Timbrinds and a load distribution hitch . I have both on my 2017 and 2019 Laramies. It is the best way to go, and they don't wear out!!!
Hobobob
Polson, MT
2021 2500 Big Horn
A lot of good advice here as well as different ways to solve your sagging rear-end. I'm going on 3 years now with the under $100 airlift bags in combination with a WDH. My trailer is about the same as yours in weight and it tows very well and is very stable. I do have to watch the overall weight I carry in the truck to try and stay below the max weight you are suppose to carry. Both, in my opinion, are an absolute must have if you are towing a 6500 lb trailer. Your tongue weight is probably in the 900+ range or it should be. Whatever you pick for bags or coils or both, you still need a WDH.
