Clutch fan removal
R/T_Fire
Pleasant Grove
So I thought I remember reading on the forum guys removing the Clutchfan and not running the V6 Efan..... I have searched and searched and read thread after thread and cant find it. Am I loosing my mind that you can run on the AC fan when you change the temp it engages at?
Was this a year specific thing? I find Matt's write up when he installed the V6 E-fan and we have the same year and it as me thinking since he knows alot more about these trucks than I maybe I should hold off just removing my fan and using my AC fan now that its colder.
Kotta390
On 2014+ models the stock a/c fan is enough for cooling purposes as long as you don't tow very heavy in hot states. Anything prior it is recommended to run the v6 electric fan on the older 3.7l 4th gen trucks. 2009-2012 iirc.
R/T_Fire
R/T_Fire
Pleasant Grove
Thanks... Figured my luck wasn't that good. I'll have to order up a fan.
Hipps2000
2013 Ram 1500 Bighorn
Hemi 5.7l
Order a oemmmopar fan you pay more but totally worth it.
Dubstep Shep
Houston
2014 R/T
I pulled my clutch fan and replaced the A/C fan with one of the V6 fans. Had to modify my wiring harness to do it, but I tow 7,000lbs in Houston heat all the time with absolutely ZERO overheating issues.
Kotta390
I wouldn't recommend it for everyone.
RFarrell222
I just did this today, one of the easiest mods I've ever done, clutch fan came off with next to no effort. It took me longer to rip the old plastic off then hook the new one up, lol
Pmexpert
6.4 SRT
What's the benefit of doing this mod?
first of all to exclude parasitic power loss, second to remove this stupid sound of a clutch fan, it stocks sometimes and a third to have a chance to install a good ATI damper that is definitely useful!
eljefe
Moyock, NC
Thanks
Sent from my HTC6525LVW using Tapatalk
bassheadhemi
Montreal, Canada
What to you guys do to protect the now exposed thread? Mine was rusting quick so I sprayed it with Fluid Film, but wondering if anyone found a cap that fit? Is the size/thread the same on the gen3?
Kotta390
I would like to know as well. Every so often I take a brass brush and clean it and then spray it with lubricant.
Hipps2000
Hemi 5.7l
I use an anti seize from Napa. It's silver in color and I just brushed good around threads. Don't put too much you'll find out it will spray all over engine bay. Brush it on and wipe in until threads are silver. Works great and no rust.
bassheadhemi
Montreal, Canada
I was thinking of getting a used/defective one and cut it to only keep the nut, but I yet didn't managed to find one...
ameer73
