Coolant troubles
NHDuckHunter8003
Jacksonville, NC
CTD 5.9
Once again I have succeeded in turning a 20 minute project into a day long affair. I just got a 180* stat and when I checked the coolant it was green. Yay. So I am in the process of getting all that crap out of my truck now. So far the best way I have found is to drain the radiator. Run the truck until its warm enough for the stat to kick on. Shut it off and drain the radiator again. Fill her up with water. Repeat. Repeat. Repeat. If someone knows a more efficient way please enlighten me for I am troubled.
Thanks in advance,
Kyle
HolyRamBatman
Deep in the Heart of Texas
Thanks in advance,
Kyle
It only gets easier if you have someone else do it.
What color was your coolant when you put it in?
Most are green.
N
NHDuckHunter8003
Jacksonville, NC
CTD 5.9
Yeah that's what figured. I'm just plugging along at it. The coolant was green and this is the first time I've checked it since I bought its few months ago.
emjohn4
Remove block plug, open radiator drain - apply low air pressure to system (coolant system testers are great for this) - remove all coolant?
Works for me.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
The Mopar coolant is redish orange, NOT DEXCOOL. Wanna make sure you get a H.O.A.T style, the dealerships sell it in a gallon jug.
N
NHDuckHunter8003
Jacksonville, NC
CTD 5.9
The dealership was chargin $24 for a gallon of the molar stuff so I went to napa and got the zerex g05 that a lot of guys recommended on here for $12 I think.
SilsHemi
The Zerex G05 is HOAT, so you're good.
