Coolent Fluid Level
Darrell85
New to the site. I have a question. Has anyone had a problem with the level on fluid in the reservoir? I fill it to the line and with in 2-3 days it is below the line. But I do not see any leaks or drips. No whole in the tank.
but get this I marked the tank below the line and the fluid never goes below the mark.
No water in the oil or anything
Any thoughts
About Strutmasters | Air Suspension Experts
Joe.G
2004 SLT Quad Cab Short Bed
Mine kinda does the same thing, If it doesn't move from that spot I Would not worry about it.
MADDOG
Living in a Firepit
6.4L HEMI
Sounds like a pressure leak. Pressure test your system. You may have a small pinhole in a radiator tank, a small crack in a hose, etc...which will only open up as you are motoring down the road.
Darrell85
Darrell85
Thanks guys I will try that. Got to keep it running good. My wife drive the vehicle a lot and want to make sure everything is in proper working condition.
