jcarlos808
Hey guys, just wanted to ask if there is a fuse for the Cruise Control. Because my CC keeps cutting out, or maybe not even engaging. Thanks in advance.
Mine has recently started doing @jcarlos808. It takes several presses to get the cruise control system to come on. At first, I thought maybe all the buttons in that cluster just weren’t working, but the “Gear -“ and “Gear +” worked fine. I think after pressing the “csc on/off” about 9 to 10 times, it finally showed that the cruise control system was on. Was there ever a solution for the initial post on this thread? In the meantime, I will try replacing the fuse to see if that helps correct the issue.Hey guys, just wanted to ask if there is a fuse for the Cruise Control. Because my CC keeps cutting out, or maybe not even engaging. Thanks in advance.
