Diablo sucks it...
Lhemi
Lhemi
OKC OK
6.7 Cummins Turbo & Hemi 5.7
Have you got your truck prepped for install?
Lhemi
Lhemi
OKC OK
Installed
Still not working but go to go!
saintsreturn
Home in St. Pete, FL
2015 Longhorn
EcoDiesel
No. I thought about it but for some reason I decided to wait till it arrives. I am going to most likely install tomorrow before work.
Lhemi
Lhemi
OKC OK
Does the screen alway stay off? Until you push a button and then it goes back off?
charonblk07
Calgary, Ab
F1-A forged 349ci
It will stay on if you've got it open to an active screen like one of the gauge monitoring screens, otherwise it will go into sleep mode but remain on, which if left plugged in will drain the battery, just a warning.
Cruizer
Ohio
2010 Sport 4x4 QC
Good info, never heard that before. So can you turn it off while plugged in so it doesn't drain the battery? Or, is it always in just some kind of sleep mode.
charonblk07
Calgary, Ab
F1-A forged 349ci
I've found that it will sleep and use very little power if you leave it on the monitoring screen, but it uses more power when it's still actively looking for data such as when you're just on the main screen.
Lhemi
Lhemi
OKC OK
That is good to know. Thanks!!!
BlackRamHemi
Edmonton Alberta Canada
Kurtis, I believe there was a bug in the newer DCX PCM that wouldn't allow the Trinity to power down like it does for the 09' and 10' Rams.
I don't know that Diablo found a fix for that yet,
I haven't been on the Diablo board for a while now
popcenator
Omaha, NE
Just my experience, I've never had an issue with the battery draining and I usually leave it plugged in on the monitoring screen and on the main screen. I know others have had issue though but I leave it plugged in all day/night.
Lhemi
Lhemi
OKC OK
Wow, we should make a thread just for problems with the Diablo, and how you fix them.
DavidRam
SoCal - Redondo Beach
2012 RCSB
FYI, for new T1000 guys. If you are tyring to run datalogs, Sean needs about 5 minutes of regular driving including one wot run 0-75, this should be done in one log. However, if you haven't downloaded the latest DS update, the T1000 will freeze in about a minute of datalogging. Return truck to stock, take DS to your computer and download the latest update.
DavidRam
2012 RCSB
Mine is telling me to reflash ECM and it will not upload tune to vehicle.
THIS SHOULD HELP YOU, TOO:
NOTE : When tuning, leave the driver side door open so the key off steps completely turns off everything.
When you get the tuner, first thing is to plug it up to your pc and run an update using dsdownloader which you can get from the Diablo website. That's found in the downloads section on the Diablo site. Run dsdownloader with the trinity attached to ur pc. Then click on the express tab and then click on update tool. Then load a preloaded tune file in ur vehicle. If your pcm isn't at the latest flash revision it will state that and then you can go back to ur pc and run dsdownloader. Click on Calibration Update to download your new pcm info into the tuner. Once completed carry it back to the vehicle and it will flash the pcm with the latest revision. If you have any trouble with that, contact DiabloSport tech support and they can walk you through it. Once that is done, THEN you can load in a preloaded tune file.
Matt440Mopar
Fort Worth TX
I'll try that if the weather isn't too bad once I get home. Thanks.
Sybil
Maybe post what you were doing wrong to help others. Thought I saw someone yesterday having similar issues. Hope it all goes smooth now. :)
Yeah, I'm sure this will happen to me!
DavidRam
2012 RCSB
DS T1000 installation: I got my instructions emailed to me by Sean at HF, and they were spot on. I did the entire install in less than an hour, with no problems at all.
Happy to share that info with anyone who needs them.
Matt440Mopar
Fort Worth TX
Well, Hello!!
She's awake now! Thanks DavidRam! Install worked perfectly that time
:biggun::mfr_omg::jawdrop:
Reticle918
