DIY: 2013-2018/Classic OEM Foglight Wiring (& some 09-12 info)
Mpgrimm2
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
and some night shots ...
Mpgrimm2
Mpgrimm2
SC
5.7L
Mpgrimm2
Mpgrimm2
SC
5.7L
Troubleshooting Notes:
* Issue: Foglight dash/EVIC lndicator does not come on when pressing the foglight switch
Fix: Have dealer activate LNJ sales code, or verify that they added it correctly. If using a diagnostic/code tool to activate within the BCM directly, ensure that foglights installed option is set to on.
* Issue: Foglights do not work, but EVIC lndicator comes on when the switch is pressed.
Fix 1: verify that 12v is present at the Wht/Org & Wht/Yel wire terminals at the bulb connectors. If not, then check at the 4 pin extension connector at the top of the bumper. If not there, then verify extension harness wires are inserted in the correct connector cavities under the PDC.
Fix 2: If using aftermarket LED foglight bulbs vs OEM incandescent bulbs, the polarity may be backwards at the bulb (LED bulb not compatible with Mopar harness).
- Try flipping the 2 pin bulb connector over and installing it to verify (may not lock this way). If it works then you need to find a way to swap the positive & negative wires to the bulb.
For 2500's you can get a 9145/9005 extension that you can de-pin the female end, swap the positive/negative wires on the pigtail and then reinstall in between the Mopar harness and the LED bulbs like this:
New (2) 9005 9145 HB3 H10 Extension Wire Harness Cable Sockets Wired Cable | eBay
For 1500's you will need a 9006 extension like this: 2x9006 9012 HB4 Fog Headlight Power Wiring Harness Extension Socket Adapter plug | eBay
M² Mods - From my non Flammable S7!
Mpgrimm2
Mpgrimm2
SC
5.7L
Mpgrimm2
Mpgrimm2
SC
5.7L
@DugboS ,
With the holidays coming up and trying to close on a house still, I'm a little backed up but will work it in as soon as I can.
Send PM with your vehicle info and your email to get things started.
M² Mods.
2ndA732
CA
Thank You! Thank You! Been looking for this for my '18. Made me join this forum! Just sent a PM to you Mpgrimm2.
Cheers.
TMyers
USMC 84' - 92'
north wilkesboro, nc
Cummins 6.7
Man, what a thread! I have quick question. My 2013 Ram 2500 Tradesman does not have factory fog lights but, it has the fog light push button switch on the headlight knob. And, the indicator light shows on the cluster when pressed on.
Could I run a LED bar in the air dam area from this switch?
Thanks in advance for the help!
duunoit
EcoDiesel
The fog light switch would be inside the round auto/off/parking/on switch. The push button switch you're looking at is for your cargo lamp. It took me a week to figure out what I was turning on :)
TMyers
USMC 84' - 92'
Cummins 6.7
Maybe I didn't write that well enough. It is the push button inside the center of the headlight knob. My cargo light is bottom right beside the dash/ overhead light dimmer.
duunoit
EcoDiesel
Oh, well you're that far ahead on the install.
Mpgrimm2
Mpgrimm2
SC
5.7L
Yeah,. It sounds like the foglight sales code may already be loaded. Did you buy the truck used? (Was it in a wreck or the bumper replaced at some point?)
Maybe you already have the 4 pin connector and wiring behind the lower left side of the bumper...
See the instruction sheet linked in the earlier posts for location and picture of the connector.
M² Mods.
TMyers
USMC 84' - 92'
Cummins 6.7
M² Mods.
Thanks for your reply. Yes, I did buy the truck used. It was previously owned by the Diesel Tech the local Ram Dealership. He traded it to get a 3500 and 5th wheel. He took very good care of the truck. I have no reason to believe the bumper has been changed.
If the 4 pin connector is there, I would assume 2 would be hot for left and right fogs and two grounds? I guess my next question is:
Would there be enough amps to run a 20" LED light bar off of one leg of the 4 pin? I don't want to burn up the switch or melt wires.
eBay has 20" LED light bars with mounts for the Ram. They mount between the tow hooks. They come with their own dedicated wiring but, I would like to utilize the fog light button if I can.
Thanks again for the help!
Mpgrimm2
Mpgrimm2
SC
5.7L
Here's a video to assist with installing terminals in the yazaki sealed connectors:
M² Mods.
Jon Moreau
Virginia
5.9 CUMMINS
Old thread, I know, but the only one I've found that shows the "extension" harness I need. Are you still building these to fit a 17 3500 Ram? If so, I'm looking for one....Screenshot_20180827-122932.jpg
Mpgrimm2
Mpgrimm2
SC
5.7L
Pm sent
M² Mods.
xzeroboyx
Indiana
6.7 cummins
Hey I’m interested in purchasing a fog light jumper extension for a 2015 ram 2500
Mpgrimm2
Mpgrimm2
SC
5.7L
Wesley0209
Ga
Hello I would like to purchase a fog light jumper extension wiring harness for my 2017 ram 2500 tradesman. I have everything else purchased in your post for the mod. Thanks
TMFMK
