NOTE: Be aware. I noticed that the Official 82214240 OEM Camera Add-On Kit's wiring color codes don't match jeepguy's color codes for his custom harnesses from this thread's OP and pictures, so it adds to the confusion.It was confusing for me to where the pins went until I saw an image I think that is earlier in this thread showing exactly where they go from the rear. The diagram in kit instructions made me think I had to depopulate some existing wires which was wrong. If you look at rear of connector it is the bottom 3 on left.
This is a photo of mine before I added the camera pins. The camera pins go on bottom left looking from the rear as shown. Hope this helps.
Thank you very much for your help and this image. I reconnected the wires as shown and the screen and camera came right no. No problems.
Brand new in the box OEM back up camera kit never used, asking 225.00 includes shipping. Paypal only
CAMERA KI-BACK UP | Genuine Mopar | 82214240
Need help asap. So I have hooked everything up and when I turn the truck on the screen is black. No radio, nothing. I have checked the harness into the back of the radio with a volt meter and it is getting powet, but still a black screen. Any help??????
Have you looked at the other thread? There are some detailed pictures there.
Once you get it working, can you let me know if you get the guidelines on the display?Hello, all. I have a 2013 Ram Big Horn with the factory RA3 flashed with Nav. On to the ParkView upgrade. First, I had the dealer flash code XAC to activate the ParkView camera, which of course resulted in a blue screen in reverse. Then, I installed the new Tailgate Handle with Camera, along with the Tailgate Wire Harness P/N 68189124AB, which now results in a black screen instead of blue. Obviously, the camera is already talking to the RA3 to some extent. Could it be possible that if I simply swap in Camera Lock Jumper Harness P/N 68096415AC, my display will be fully functional in reverse??
- If you decide to install the official kits, look at cptwing's "Installing OEM backup camera" thread for more accurate info:
Cptwing's - Installing OEM backup cam
I'm on the road but there is a very good picture of the connector over there in the thread by me from the instructions. Real pictures too.
