Do I need a limited slip
badblackram06
MS
I have some 4.56 gears on the way. What would be some reasons that I would need a LSD? I mean I know for traction. But will I really be able to break the tires loose with the 4.56s mind that I have the 4.7l..? Not that I will be trying to. I'm really just looking for a little more acceleration.
I can get a stock unit that has been rebuilt for under $200. Would an aftermarket unit be worth the extra cost?
Chewy
Bettendorf IA
V8
Ever drive in the rain? You'll want it!
Sent from my miniaturizer via tap dancing...
badblackram06
badblackram06
MS
Ah I see. I've never had a posi so I really didn't know how it would work. Thanks
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Yep if the truck didn't come stock with it now's the time to dump on in the rear.
badblackram06
badblackram06
MS
Alright looks like ill be saving my pennies on a Detroit truetrac. Seems like its a good investment.
09SMOKINHEMI
TEXAS
For sure.... I'll be doing the same soon :D
sent from my Samsung Galaxy S3
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
You might also like Auburn. I like it works well with 4.56 gears and in town driving.
$miley
Sauce09
Hutto, Tx
You can never go wrong with Detroit. Put one in my 02 Camaro and I beat the crap out of that thing, never had a problem. Same with my '77 Ford f150 460. But I've also only heard great things about Auburn.
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
2019 (2003 Forgottens SOLD and 2014 SOLD)
Hemi 5.7 (392 Hemi) 86 Ford .308 HO Roller
Not gonna Bad-mouth The Detroit, but ......Auburn........Is the **** for the Street Man! LT285's Don't stand a chance with 456's in em.
badblackram06
badblackram06
MS
Hmm it is about 70 bucks cheaper. I may end up owning an Auburn if its as good as you guys say.
If I do consider the Auburn. Is there any difference in fluid changes? What is the normal life expectancy on the clutches before its time for a rebuild?
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
The Auburn Uses straight GL5 Stuff (pretty Sure 80w90) and absolutely no requirement for synthetic. The Company provides Friction Modifier but also recommends to use the Ford Friction Modifier (I use that). The diff will likely outlive the Truck unless you do Standing Burnouts each and every single day. So I guess I am the Opposite cause I run Full Synthetic in the C205.
SuperDaytona
Oceanside, CA
If you are trying to get performance out of your truck, you would def need a Limited Slip! My stock 3.92 with my mods gets my one wheel a spinnin. I need some traction to grab the road n go!
badblackram06
badblackram06
MS
Well I got the truetrac and the install kit ordered. It should be here tomorrow according to the FedEx tracking info. Hopefully I will be able to put it in sometime this week.
Tapatalkin!
ramin44s
4.7 v8
Should be sweet I need to do this my self did you find a good deal?
badblackram06
badblackram06
MS
I got the install kit through Moes and it got here quick! I was able to order the truetrac through my work and got it for around 460. I thought that was pretty good. They had a deal going on and I got 2 free quarts of fluid with it. I dont think its enough but I'm not complaining.
Tapatalkin!
Orca
