tman1112000
my 2015 squeaked like insaneeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeely alot when i bought the truck 3 months ago now tryed all kinds of lube as well nothing worked untill ( white lithium grease from walmart aint made a noise since )
Nothing has worked to stop the squeek. Not lithium grease, silicone spray, numerous other spray lubes, nothing worked except WD-40 and it only lasted about a week. Since installing my rubber o-rings it has been quiet.If that's the case, it didn't work that way on my driver door. The roller works it way all the way up the post and stays there. Then it would stop rotating due to the friction between it and the top of the post. I would lower it and lube it only to have to redo the process constantly.
Glad to hear it. Mine was the same. I tried everything but it always came back until I put the washer in.Nothing has worked to stop the squeek. Not lithium grease, silicone spray, numerous other spray lubes, nothing worked except WD-40 and it only lasted about a week. Since installing my rubber o-rings it has been quiet.
what size and from where?I went with an HNBR O-ring. Every lube under the sun & it still ends up squealing. So far no noise. It just works!
I'll come back and edit this post when I have the size after I get home but I have a generic assortment for doing Auto Air conditioning repairs that I got years ago from an auto parts store like this onewhat size and from where?
Just pop it on over the roller's pin.Some pretty good ideas , my question is How do you install the O ring ? Does the pin pop up ? Thanks
Cool. Thanks That is what I was thinking but I get in trouble when I think sometimes lolJust pop it on over the roller's pin.
O-ring kit link from Advance Auto
Good enough for me... THNX
Amazon.com: Beduan AC376M 270pcs Compressor O Rings Kit 18 Sizes Car Air Conditioning O-Ring Assortment Set (Green): Automotive
Buy Beduan AC376M 270pcs Compressor O Rings Kit 18 Sizes Car Air Conditioning O-Ring Assortment Set (Green): O-Rings & O-Ring Kits - Amazon.com ✓ FREE DELIVERY possible on eligible purchasessmile.amazon.com
same $ as Advanced, but delivered to my door for free... Thnx agin
Where did you get this and what size o ring are most guys using?I went with an HNBR O-ring. Every lube under the sun & it still ends up squealing. So far no noise. It just works!
