Dreaded cold start lifter tick
Bigskyroadglide
Montana, except for work
Hemi 5.7, supercharged
On my 2011 ram 1500 4x4 5.7, I have 159k. Since I have another daily driver this truck now sits, three months at a time.
I run redline 5w30 and a SRT filter. If I start it after three months of no start, it knocks like it's coming apart.
If I hold the gas pedal to the floor and crank it for 15 to 20 seconds, it will circulate some oil and it does not knock on start.
So my remedy is hold gas pedal to floor, crank for 15 to 20 seconds, then let off the starter, then tip start as normal.
No knock or tick.
This works, it's free, and is built into the computer program for the hemi as a safe guard.
Just my .02
HEMIMANN
Minneapolis, MN
2017 2500 Laramie Crew Cab
6.4L HEMI
No knock or tick.
Just my .02
Way cool. Thanks for sharing.
How did you find out they put in pre-lube function @ WOT? Never heard of this before. Very useful if applies to all model variants with Hemi's.
HEMIMANN
Minneapolis, MN
6.4L HEMI
Oil viscosity always decreases with increasing temperature (with no load). The only question is how FAST the viscosity decreases with temperature - this is what viscosity index tells you - it's just the slope of the viscosity vs. temperature curve.
Those are just the basics - when we discuss viscosity in highly loaded and highly shear machine elements, very strange things happen. I won't get into that here. You can see discussions elsewhere.
- Former Mobil Industrial Lubrication Engineer
Bigskyroadglide
I saw it on a you tube video. Then tried it with my ram. You can set your evic and see the oil pressure come up. It's used mostly with dry engine start up on replacement.. like 16.20 on the video
HEMIMANN
Minneapolis, MN
6.4L HEMI
Thank you!
Sheeeeit.....you'd think they would publicize the snot outta this pre-lube feature to prevent failures?
BWL
Embrace the skeptisism
BC Canada
Anybody try the pre lube on newer rams?
HEMIMANN
Minneapolis, MN
6.4L HEMI
I can't remember to try it. If 2017 even qualifies as newer. It's previous gen already.
I'm lucky I can still remember where the can is instead of ******* down my pantleg.
BWL
BC Canada
Just went out and tried it on my 2017. Worked
BWL
BC Canada
Keyless go so I had to stand on gas and brake at the same time. Took me a moment to realize that's why it didn't work first try. Cranks for longer than I expected.
chrisbh17
This was going to be my next question! How it works without something to actually crank (i.e. no key to turn)
