E brake cable hitting frame
MoparFin
U. S. Navy Vet - AS1
PA
I like to drive with all the windows down a lot and I have been hearing a lot of banging. Figured out that I think it is the E brake cable tensioner hitting a frame gusset. The cable isn't sagging. Anyone else have this and if so, did you fix it?
Truck is a 2018, 4x4.
jws123
nj
Not sure what a 2018 looks like but see if it has this foam thing on it I assume its to keep it away from frame Your cable also may just be lose enough to make noise.s-l1600.jpg
MoparFin
MoparFin
PA
Not sure what a 2018 looks like but see if it has this foam thing on it I assume its to keep it away from frame Your cable also may just be lose enough to make noise.View attachment 495059
It has the foam, but the part thats hitting is the part to the right on the picture. Cable is tight-ish. I wouldn't want to adjust it any tighter.
