E fan ?
MikeG
Livonia La.
I'm wanting to put my dual fans in. My question is if I disconnect the factory fan will it set a CEL ?
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Which fan setup are you looking to run? If you go with the factory v6 fan, it is plug-n-play and will not trigger any CEL's.
joeshemi
orlando,fl
does the v6 fan push or pull enough air for our hemi motors?
wickedwhite2012
Baton Rouge
Put the v6 Efan and the jet 180 stat. If you dont have a tuner it with turn on at 225 and shut off about 200. I think. With a tuner i set mine to turn on at 200. For me the fan never comes on unless you sit in traffic for long periods of time or you turn the a/c on. Before the turner came out when i sat in traffic i just turned the defrost on. One of the top mods you can do.
MikeG
MikeG
Livonia La.
I plan on running the 180* but I want my temp under 200*
This truck tows every day. It needs to stay cool.
This weights 8100 loaded
MikeG
MikeG
Livonia La.
No tuner yet. I'm waiting till I'm done with all my mods before I do a tuner.
I will be putting these in next weekend.
I want to use these cause I can set the temp that I want them to come on at.
ramguy11
What does the fan upgrade do?
craigsez
Novascotia,Canada
E fan is an electric fan..Stock rad fan uses engine power off the pullys n belts to spin the fan with a clutch,so it robs power and a lil mpg
WhiteExpress
Midland, TX
I haven't seen a CFM rating for the V6 Fan, but my honest opinion is, it's likely a whole lot more than most after-market fans will pull. And it's a clean install.
It's ANOTHER reason I want a tuner, so I can trigger the cooling fan at the right temp.
TylerB
FL
The V6 e-fan pulls plenty of air, it'll pull a sheet of paper against the grille at low speed, high speed you can forget about it. I've got mine set to come on at 188 with my Trinity and it never gets hotter than that even after back to back passes at the track.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
What is the part number on this plug and play setup?
$miley
