BoDuke
Has anybody successfully swapped to e-fans on a 5.9l 360? Im interested in it and would like to know more about it.
I run a single 17 or 18" fan (forget which) from a 1995 Ford Thunderbird 4.6L. OE fans like that have a bit higher amperage draw but are SOOO much more effective than most aftermarket units unless you spend big money. It's a 2spd fan that produces over 3000cfm on low, almost 4000 on high. I run dual auxiliary temp sensors to a relay control unit, low comes on at 185, high comes on at 200. It's wonderful, hell the low rarely even comes on with a 180 tstat.
Edit: my relay kit that I have is unfortunately no longer available. Its awesome though.
I don't see how the newer body style would change anything other than your specific mounting setup for the fan itself. The wiring won't be any different if you used the same harness. Problem with that is it's not available anymore. You'd have to find another harnessI was hoping you would post on this with some awesome knowledge and you did. Which is great, but i do have a few questions really about the wiring and how you did it. I already have the 180 tstat but the deal with mine is that its a new body style 02 with the 360 would that change everything?
Could you post some pics of your set up so i can get an idea of how it works and ill keep searching for a harnessI don't see how the newer body style would change anything other than your specific mounting setup for the fan itself. The wiring won't be any different if you used the same harness. Problem with that is it's not available anymore. You'd have to find another harness
Sweet i thin that would work best for me. I use mine as a work truck no performance really other than red light to red light lol but i do alot of towing with itDefinitely possible. Fan controllers come in both dual fan and single. I think 2 single controllers might be easier to do for something like that. 1 come on at say 180 and the other at 195 or 200. Plenty of different versions available.
