Non-failed e-torque?
CRS1968
Edmond, OK
2023 Limited with 50,000 miles. Built early 23. No etorque issues. Bad clock spring results in blinker not returning to neutral without a full turn. Love this truck!
Alfonzo409
5.7 eTorque
2019 Laramie 5.7 with Etorque 88,600 miles no etorque problems at all yet. Bought it new in June of 2019. Only issues are, recently my 12” screen will blink/flash on and off (not always and it seems to be some kind of interference because it doesn’t do it while off the throttle) and I have had a battery drain problem. Something drains the battery DEAD! Has happened 3 times so far. Two other times I noticed the instrument cluster was on and the 12” screen was backlit while the truck was sitting, untouched for hours. Disconnected the battery overnight cause the panels would not turn off no matter what I tried.
My dad had a 2019 limited with etorque and his drained the battery so often that he always keept a charger on it while parked. Something would drain his battery dead in less than 4 hours. He finally traded it in. He never had any etorque problems.
azaustin
5.7 Etorque
2022 RAM 1500 Laramie, almost 41000 miles, 10000 towing 22 foot travel trailer. No issues. 2021 Jeep Wrangler Unlimited Rubicon E-Torque V6, no issues. Both vehicle have had the original battery replaced.
hondajohn
2019 1500 Bighorn with V-6 43K miles no issues other than the rear brake light leaking.
Randy Grant
Army
KITTITAS, WA 98934
The old adage that the squeaky wheel is easy to hear is certainly true. The other four are quiet, because nothing is wrong, although there are more of them. I really think that the vast majority of eTorques are without issues. Whether they are worth the expense is a totally different question, and for the cost, I don't think it is a break even situation. If it had been an option I probably wouldn't have ordered it, but it was on the lot, and so it's what I got.
Hawkman
Law Enforcement
South Carolina
No issues on my 23 with eTorque so far after 30 months but miles are low. Only real issues to date have been small leak at the rear window that I cured myself and the left turn signal canceling that took a vacation for a couple of months before returning to work.
Having an issue with a leaking rear window in mine. It was replaced in Sept, but leaking again.
How did you fix yours?
MikeinTenn
Tennessee
2023 Limited 5.7 eTorque 42k miles. Purchased new end of March, 2023, so exactly 3 years old. Occasional short-distance towing. Driven regularly (several times per week), 10+ miles each way to town and back. Also has made several 5k mile trips. Very little ciity or stop-and-go driving, always turn off golf cart mode. No issues with eTorque but have just replaced leather dash.
Jim64
WV
22 bighorn built to serve edition 5.7 eTorque 67000 no problems with anything on that truck.
DanAR
Arkansas
I bought some double tube rubber weatherstripping at Lowe’s and split it down the middle so it was a single tube piece and used popcycles sticks to wedge it into place down behind the glass out of sight. Blurry photo.
DanAR
Arkansas
Ugh - hate to hear you had leather dash problems on a 23. I had hoped they had a cure for that by then. I at least use my sun shade anytime I park it outside the garage but I’m not sure how much good that does overall.
Brahmajoe
Law Enforcement
Connecticut
I just got a 2026 hemi with Etorque, I get nervous reading about the electric motor and battery. Say a prayer for my truck hopefully it has lots of trouble free miles like the ones in this thread.
Hawkman
Law Enforcement
South Carolina
Thank you. Actually heading to Lowe’s when the wife gets home. Will
Look for this while I pickup some grass seed and mulch.
TimboRam77
21 limited purchased 2020. 42000 miles. Etorque no issues other than inconsistent regen braking. Very little braking on a good day. Far from a 1 pedal driver. Basically an epa required waste. However the truck was a 100% match for my desired build and was amazing at my local dealer.
Art_in_CO
Colorado Rockies
2024 Limited
My 2024 Limited 1500 is now 26 months old, but only has about 11,800 miles on it. So far, the only issue I've had (knocking on wood.....) is a defective original 12V battery, which I replaced myself with an Odyssey AGM.
Nashveygus
Nashville TN
'21 Laramie 1500 purchased new in Aug. '21, 37k miles no issues with etorque nor any other quality issues. Replaced OEM battery with Optima Yellow Top AGM in 2023, charges great. Rides awesome with standard suspension, tows my 21' tritoon like a boss. Averaging 16.9 city 21.5 hwy mpg.
TC
Central TX
New to me 24 Laramie with 56k miles, no issues so far. I did recently change both bearings in the MGU as preventative maintenance due to a slight to moderate bearing noise during operation. Rear bearing was a little noisy but had not failed. Front bearing was in good shape but replaced it anyways. Both tensioners replaced first, noise was still present so off with the MGU. Now, quite as a mouse and charging perfectly.
olyelr
olyelr
Kewadin MI
Is the bearings something you did yourself, or something the dealer did?
GeauxinUp
Navy Badge
Louisiana
2026 Limited
3.0L TT H.O.
I ASSume the eTorque system is covered under the 10yr/100k powertrain warranty?
giantturkysub
