Efan conversion temp settings?
Tfrizz80
Just did my efan on my 2012 ram 1500 hemi thanks to this you guys hard work...thanks...got my dcx from hemifever. Changed to a 180 themostat. I saw someone set there fan on to 195. is this good? Whats a good fan on temp and fan off temp?
Divi
i have mine at 190 and 200. but it always comes on at 185, so not sure whats going on with mine, but it kinda works
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
You want to set the fan to come on a few degrees higher than your thermostat...this way the fan isnt always running. The fan shuld be off while you are cruising on the highway and only run when you are at idle, in traffic, or driving slow around town.
Tfrizz80
Tfrizz80
So I should make it come on at say 185 and what temp to go off?
Tfrizz80
Tfrizz80
Sure could use a complete answer for this. In the dcx it has a fan on temp. Under the fan off it has a high speed and a low speed setting. thanks
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Set your low speed at 185, and the high speed at 195. That should work out fine for your 180 stat.
TylerB
FL
I have mine set at 188 and 198.
Tfrizz80
Tfrizz80
Well I have a setting on ac fan on for the temp. Then I have 2 settings for ac fan off
High mph ac fan on
Low mph ac fan on
So im not understanding or im missing something....
TylerB
FL
Low mph acc off-188
High mph acc off-198
acc on-188
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Is your motor running at 180* or is it running hotter than that?
Tfrizz80
Tfrizz80
Levels out about 186. I put the low mph setting at 194 and the high mph at 202 and the fan on setting at 202. It still stays on
Tfrizz80
Tfrizz80
Anyone know any other ideas? Why does the dcx have the high mph and low mph settings and a seperate fan on setting? Are these needed? What do they mean? Thanks
Tfrizz80
Tfrizz80
Ok got it figured out. I set all 3 settings to 202*. Fan kicked on at around 201* and off at about 190*. The settings on my dcx starts with a ac fan off. Under ac fan OFF theres 2 settings... high mph ac fan ON and low mph ac fan ON. Thatd what was throwing me off. Anyways thanks for the help.
electricalservice
