"Emissions BS"
Dodgeguyyy
Louisiana
Question guys, I just bought a 2022 ram 3500 6.7 HO with 67,000 miles on it. Should I go ahead and get all the "BS" taken off of it?? Before this one i had a 2016 2500 and had the "bs" taken off and had zero issues with it other that the turbo actuator (which was an issue before I took the "bs" off) its goin to be done, im just wondering if it's worth it to do it now or wait a few more thousand miles.
rzr6-4
nebraska
'09 2500
If you know you're going to do it, I see no reason to wait. I would probly only mess with it though if I knew I planned to keep the truck for a while.
mtnrider
Georgia
Given the possibility of lifter failure, I would keep my warranty for a while. That and deleting a 22-24 is very expensive and requires a ECU swap. You are talking $6K+. I would let the warranty run it's course and if the day came where I had a emission issue that the warranty wouldn't cover I would then consider a delete.
Riccochet
Somewhere around Charlotte
2020 2500 Laramie Longhorn
what warranty? His truck has 67k miles on it.
Fuel35 67
Hanford
Isn’t it “X amount of years or 100k, which ever comes first”?
Fuel35 67
Hanford
Then wouldn't he be out of warranty now?
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
Did you buy an extended warranty? All the googling I've done shows the powertrain warranty being 5 years or 100k miles.
I did not. They tried to but I denied. Nothing on my paperwork being charged for it but it shows on Mopar website when I log in for my truck/ vin. I don't know but I did just double check.
nlambert182
Huntsville, AL
I wouldn't do it unless it was out of warranty and I had to. The second you touch it the warranty is void. As most have said, it's not as easy and cheap as the 4th gens and does require a complete ECM swap.
