engine brake
fordram guy
hemi 6.4
Hey guys i need some info. I have a 2015 2500 ram and i pull a horse trailer bout 16-17000 pounds. The truck is going to 5000 rpm in a coasting situation. Say like i am coming off a hill i let off the gas and i will be at 2000 rpm and all of a sudden its at 5000. I have taken it back numerous times now and they are telling me that these trucks have an engine brake can anyone confirm this cause i can't find anything on it
KarL45
Western Slope, Colorado
2018 Ram Express quad cab 4x4
5.7 MDS
Think you will find the only "engine brake" is the engine compression. That said, every time you apply the brakes, in Tow Haul, it will downshift a gear or probably, if your using cruise, will downshift if it gets much past your set speed. I would say, get out of the tow haul, lessen your speed a bit at the top of the grade, and manually downshift and try to keep the rpms around 4k. That's what I generally do when towing 13k 5'er. I also then use "sparingly" the trailer brake to moderate the speed.
xrsman
Ontario
3.0 Ecodiesel
What he said ^
Aren't you over towing capacity with the gas engine when you're pulling 16-17K lbs? For that kind of towing you should have bought a diesel. Much more power and much better mileage when pulling that weight. Plus then you'd have the exhaust brake which definitely helps!
