Engine Build
H
Hagar1
Ontario Canada
2012 Ram 1500
Here is a photo of a Hellcat oil pressure spring compared to a regular spring. Hell cat spring is in the middle. Hellcat is about 1/4" longer and and much stronger. I could see much higher pressures with the Hellcat spring.DSCN0073.JPG
EdGs
FL
If you've got the hellcat oil pump, just swap in the stock oil pump spring into the hellcat oil pump.
I did this on my '15 that I'm in the middle of repairing.
H
Hagar1
Ontario Canada
2012 Ram 1500
If you've got the hellat oil pump, just swap in the stock oil pump spring into the hellcat oil pump.
YUP!!! Done that already. I think a little boost by adding that 1 stainless washer won't hurt. Might make about a 5 psi increase.
H
Hagar1
Ontario Canada
2012 Ram 1500
Interesting.
I've played around with engines for a long time. The old washer behind the spring is an old trick. a single washer might not even do 5 psi, but it will give it something.
I've been retired for almost 20 years and somehow, I have forgotten stuff.
crackerjack1957
2014 Sport 1500 CC 4x4
Hemi 5.7...65RFE...4.56
You have to make room for the new data.......old has to come out........ LoL
That's what I tell everyone
H
Hagar1
Ontario Canada
2012 Ram 1500
Well, I did have what some call a mini stroke last spring so I guess the data storage is getting cleared a bit, just not in a good way.
