The dealer mentioned part number 68346912AC which is the replacement for the one you linked. I'll still reach out to the website to see if it is really in stock.
Ninja edit: The part number 68346912AC is the current replacement part. Both 68346911AC and 68346912AC are on back order. I have reached out to everyone that lists the parts as "in stock". I also reached out to Griffin Auto Group who supplies my area and got the same answer with no ETA.
There are lots of different part numbers that fit the same trucks. Basically for the 5.7 Hemi, there is a car water pump (Challenger, Charger, Durango, Grand Cherokee, Etc) and there is a truck (non EGR 1500s) water pump.
The car water pumps are interchangeable and the truck water pumps are interchangeable. If you are limiting yourself to a specific part number, you may be waiting for a really long time. Mopar is weird with part numbers, pretty much every single iteration gets a different part#, depending on which plant it was made in, which date, etc.
If you need convincing, lets take this Napa aftermarket water pump. Part# TFW 43559, which it says is guaranteed to fit my 2013.
Napa lists the same part# as fitting your 2018.
The same Napa water pump fits both trucks. If you look at Oreilly's, Advanced, Auto Zone, etc. You find the same. you can logically infer that the same Mopar pump fits both trucks too.
I made this assumption and took the associated risk when I replaced the water pump in my 2013 back in January. I used a pump that some websites said "doesn't fit" and that Rock Auto said "fits". Same with our Durango. I just ordered the Durango OEM Mopar pump that RockAuto listed, even though MoparPartsGiant showed it as being for a Challenger and "doesn't fit" the Durango.
They both fit.
