Engine stall while driving 04 Ram Hemi
nsakkis
Tampa Bay
Having an issue with my motor stalling. I have -
-New battery
-New Alternator
-New Throttle Body
-New Fuel Pump
-No fuel delivery issues that I can see
Has to be something else electrical.
Anyone else run into this issue?
When I can get it to start and drive it will just shut off while running like someone took the key out of the ignition.
Thanks for any help
Oliver Closehauf
Cincinnati
2005 Laramie
Cummins 5.9
sounds like crank or cam positions sensor going bad. You have any codes?
Jwhaley
Wisconsin
Does it start right back up? I have a 2005 that was doing this intermittently. It was like the key was shut off. It started back up fine Long story short replacing the EGR solved the problem
427invader
Shippensburg, PA
I had the same problem. I replaced multiple parts just to find out it was the EGR. Replaced that and all is fine.
