Extended sway bar links’s?
Robram59
Indy
I purchased a 1998 Dodge Ram 2500. It was lifted, and everything appears to be in good condition. But the sway bar links are broken in the front on both sides. I can only assume that when they installed the lift they put the originals back on and cranked them down. So after a little riding they broke. My question is how do I go about ordering new ones. Any help would be appreciated. Thanks in advance.
DodgeTx
SEGUIN
5.9L Cummins, 5.2l v8
can you post pics? There are quite a few aftermarket. Autozone has some, I would remove your old ones, and see if you can find some that are longer. you can enlarge the hole if needed, but shouldn't be required.
