factory brake controller
R
ramtaz64
Blackwood, NJ
You might check to see if they will install it for you as well if you supply the factory parts. That sounds about right though. That's about the going hourly rate for dealer labor these days proably takes them 5 min but they are going to charge you one hour anyway. If they install the unit maybe they will throw in the programming.
One dealer gave me a price to install the controller.. $290 for parts plus labor....... I found the parts online for $135 from moparpartscorp.com.
Still deciding if I want to do all of this. I already have the Tekonsha P3 my uncle gave me brand new..
NapaRam
Napa CA
Hemi 5.7 L
Parts and labor for $300 seems resonable but if you already have a controller that works it may be a little much just to get the factory look.
R
ramtaz64
Blackwood, NJ
Am I missing something? I looked on moparpartscorp.com and found this:
https://www.moparpartscorp.com/oem-parts/mopar-electronic-trailer-brake-kit-switch-68105206ac/?c=Zz1ib2R5JnM9Y2x1c3Rlci1hbmQtc3dpdGNoZXMmaT1UTTEzNjUwNSZyPWxheWVyXzYmYT1yYW0mbz0xNTAwJnk9MjAxNiZ0PWJpZy1ob3JuJmU9NS03bC12OC1nYXM=
Only $35 for the switch. What else would I need to buy to put the factory brakes on my truck?
Your going to need 4 parts to make it work
Electronic Trailer Brake Kit, Switch
Part Number: 68105206AC
Module-Trailer Tow
Part Number: 68336235AA
Electronic Trailer Brake Kit, Bracket
Part Number: 68160146AA
Electronic Trailer Brake Kit - Screw
Part Number: 6509940AA
times 3
R
ramtaz64
Blackwood, NJ
It was $290 for the parts PLUS labor.. I have to assume they are gonna hit me for an hour which is $135 per hour..
Yeah I already have a controller so I am having a hard time pulling the trigger and doing this...
Mudders Beast
Georgia
Just added by dealer last week on a 2017 1500 Laramie crew cab, $290 parts, 2hrs labor at accesory rate of $85/hr....Although OEM site lists 1hr. Works fine. Computer had to be on sleep mode overnight before trailers 1-4 options showed up on settings screen (8.4 Nav). Found out there were 2 different labor rates, $121 for repair, $85 /hr for accessory additions.
