Fence panels
F5Chaser
DFW
Has anyone hauled complete 6x8 wooden fence panels flat on the bed of a bone stock Hemi 2wd crew cab? I need to replace a section of fence and need about 7 panels and don't really want to rent a trailer. Total weight, per stated figures of each panel is well within payload capacity. It's under 1000 lbs total. Distance traveling is 5ish miles on city streets(45mph) max. Thanks!
HDGoose
L6 Diesel HO
Support the panels at an angle and step them down. You'll be fine.
lpennock
Army
Phoenix, AZ
5.9L & 6.7L Cummins
6 ft wide won't fit flat, it is just over 4ft between the wheel wells.
Sent from my SM-T500 using Tapatalk
turkeybird56
Central Texas
Put in on an angle, and secure properly, lean to right, stay in right lane U be fine. If bed not treated, side against bed put a cover or something on it. If U talking just laying on the side rails, U best really secure em, so none get caught and turn into a flying missile, all IMHO...
F
F5Chaser
DFW
Thanks for the input. Just brainstorming out loud and thought the bed rails and make a couple trips would work, but why work harder than necessary. Trailer it is.
turkeybird56
Central Texas
RoadRamblerNJ
Mountain City, TN
392 Hemi
Borrow a trailer from someone.
^^^^^^^^^^THIS!! ^^^^^^^^^^
I did lean them on my '84 Ram for a 3 mi.
trip. I hit a pot hole and the weight caused the side wall of the bed to tear away from the truck! Granted, I had a few more than you and mine were 4x8x5/8 stockade fence but, where is the line? I didn't know. HomoDepo rents trailers for 20 bucks. Do that.
Sent from my SM-N910V using Tapatalk
2003F350
6.7 CTD
It is NEVER a good idea to put panels laying on top of the bed rails. It is REALLY hard to secure them properly in that orientation, because they want to slide off.
Angling them in the truck bed is the best way to put them in the truck, plain and simple. If you have enough you can band them together, stand them upright, and strap that down, but it's a lot more work.
I have to admit, though, that now that I have a trailer, I find I use it for a lot of things I used to force into the truck, even if it wasn't the best idea. A trailer just makes things go so much more smoothly, and it's much lower to the ground too, so I don't have to lift things as high.
