Finally installing my ARH LTs
D
Dirty D
Auburn, CA
Assuming you have a Crew or Quad cab how far past the cross member does the ARH connection go?
I.E. if I cut right after the factory "Y" pipe connection to the mid pipe will I have enough mid pipe left to connect to the ARH "Y" pipe?
ok! got your numbers!
the ARH tubes stuck out 16in pastthe back of the cross memeber
i measured my mid pipe from the ARHs to the borla S-type catback and it was between 39-40in. sorry about the delay man!
16WhiteQC
Hudson valley, NY
I was away for a bit.
You are AWESOME!!!
Thank you so much, this will make the install way easier now that I know I can cut my mid pipe by the factory joint!
