Flipping the tie rod from top to bottom.
ercmesser
Tampa, Fl
Done a lot of research on the net, with no answers. I know people have done the opposite flipping the tie rod to the top on Jeeps. Has it been done on a ram? Putting the tie rod on the bottom. I have a 4/6 drop with spindles and springs up front, causing my steering link is at a high angle, cause bump steer and when I'm in a lock turn tires are jumping. Any help well be great.
NITROUSCHRIS
consumer of excess fossil fuels
Wisconsin
blown 6.1
Only time ive seen it done is on GM trucks. You reem the spindle and install an insert tapered the opposite way. have not seen it avaiable for the dodge and im not sure the taper is the same between the 2, that you could use a GM kit. The kit i had for my Chevy was from DJM.
E
ercmesser
Tampa, Fl
That's what i want to know if the taper and size of the reamer and insert. If the jeeps would work? Its been done on jeeps, mustangs and vw for bump steer. Seen one time on a ram but no details.
Bad Habit
Land O Lakes
Modded 4.7l
I asked my buddy this question saturday night at our minitruck meet and he said it would really mess up the bump steer.
