forward collision warning (fcw) broke?
mynameisante
US
5.7L HEMI
2021 rebel. fcw lights came on on my dash. i went into settings and tried turning on/off. lights still on dash. went to dealer for a recall a couple weeks ago and i asked about it, they looked into it and said repair can be upward to $2,000. anyone have an issue like this they were able to fix for... "cheap?"
no need for replies of "wHy Do YoU nEeD iT." short answer- i want everything that i paid for to work
jws123
nj
Did you hit/ run over anything? thats the most common failure for distance sensors.
BossHogg
Navy Badge Law Enforcement
Oakland Township, Michigan
6.7L Cummins
Do you have adaptive cruise control, and if so, is it working correctly? The FCW module is a standalone module that costs around $300. If your adaptive cruise control is working, then the radar (windshield mounted) unit is working, and it is likely the FCW module. To pinpoint the failure, you will need an OBD scanner capable of reaching all modules, showing live data, and issuing diagnostic commands.
If you recently had a windshield replaced, this could be the source of the failure. The calibration wasn't correctly done.
mynameisante
mynameisante
US
5.7L HEMI
I dont have ACC. I had no work done to the truck at all (except for routine maintenance). It just stopped working out of the blue
