Front end click noise!
Ridgeram
Canada
So this is my first post.
My truck is making a click noise when wheels are at full lock or even close too it. Reverse or drive. 33". Tires but not rubbing.
Crawled under and found a polished looking spot ( contact between lower control arm and spindle ) on driver and pass. Side !
Id this contact normal for a steering stop? Is something wearing out?
Cant find any ball joint slop or tie rod end play ?
Any info helps guys! Thanks!
The Assassin
B-more careful, Murderland
Tell us more about the truck. Are you lifted? How wide are the tires? What wheels are you running? How many miles? Do you do any off roading? PS welcome!
R
Ridgeram
Canada
Its an 06 1500 hemi 4 door.4x4 50miles .
Stock 20's with 285-65-20 bfg all terrains
No level.
No off-roading
No towing
All original suspension parts. Wheel bearings replaced last year
The Assassin
Hmm, the contact point where the tire is rubbing at the LCA I would say wouldn't be a "clicking" noise...
My guess would be a ball joint. Perhaps even the dust covers rubbing on the backside of the wheels.
bigtigga84
dela....where?
I have the same "polished" spot. No click though
quietpeen
2021 TRX
Hellcat
welcome to RF. that's amazing to Have an 06 with just 50 miles on it. Just kidding.
NJDodger
Armpit, NJ
Does the click sound like a cross between a socket wrench and a bb in a tin can? I am trying to diagnose the a clicking noise too cept mine happens if I turn the wheel about 1/2 turn or more. Mine is an '06 as well.
Sent from V-Tac Inc. Mobile Command Post.
Ram_bo06
Boston Ma.
I had a click at full lock. forward or reverse. Took it to the shop ended up being a broken tie rod.
NJDodger
Armpit, NJ
Oh and I've had the same "rub" marks on my control arms since mile 6.
The click is pretty new though
dripley
hickory, nc
2002 2500 ho 6 speed 4X4
5.9 24v cummins
you have a straight axle or independant front suspension? i have heard that cv joints will click like that when they are going out.
R
Ridgeram
Canada
The tie rods appear to be in good shape?!
Any way to determine if they are on therw way out?
JP03
New Jersey
Cummins 5.9
same have the exact same problem
R
Ridgeram
Canada
Well i checkednout the tie rods today and they "look" good.
Everyone who hears it says it sounds "tinny"
Maybe the rotor shields?
Anyone else have any input ?!
NJDodger
Armpit, NJ
Yep tinny. Started right after i did my front brake pads.
