FRONT END - POP noise??
ljonSFCA
CA
Sup Ram peoples! joined this forum today hoping yall can help me find this dang pop noise coming from the front/Left end of my new to me Ram..
it's an 03 1500 Laramie 4x4 w/ the 5.7 hemi. has 80k miles..
getting a pop from the front end when I'm reversing or parking, turning the wheel then hitting the brakes.
just hoping someone might recognize the sound and can maybe help me diagnose, so I don't go cray replacing parts & wasting money!! any tips on where to look & how is appreciated!!!! here's a link to the video/ sound -
Jon
02ramboi
live oak florida
4.7 v8
Sounds like ball joints to me these rams are notorious for those to go bad when mines went bad I redid the whole front end I suggest you do the same especially if it’s all original
Ian_Olivas
San Antonio,Tx
4.7L Magnum
If it's when your wheel is turning and normally in the morning on the first start of day. It's your rack and pinion. And I'm 100% is most likely that since you said turning your wheel. Replaced mine and all gone haven't heard them since
ljonSFCA
ljonSFCA
CA
SOLVED: well after replacing lower ball joints, inner & outer tie rod ends, Sway bar -end links, control arm bushings.. it still had a pop!! ended up being four bolts on the cross member between the front lower control arms, they were tight, but not tight enough. had to torq way down. pop is gone haaaaaalelujah.
