Front power windows not working
Midnight Storm
One Badass Ram
Victoria, B.C Canada
Any help here?
My drivers window is open an inch and won’t go up or down. I can’t control the passenger window either but I can do the back windows.
the panel lights up still.
Midnight Storm
Midnight Storm
One Badass Ram
Tested the connection. Still won’t work. I think it’s just one large relay for all the windows so the fact that the rear windows and the side mirrors still work means it’s a bad switch?
Ricks Ram
Will your passenger side window roll down with the passenger side switch? In any case you could check for possible DTC codes with the Alfa tool just to see if anything comes up but I would be leaning towards the switch or the door control module being the issue. The switch isn't expensive. Make sure when you buy it you don't get one of those cheap Chinese knockoffs. I recommend contacting Benny at Allmoparparts.com in the vendor section of the forum to order the new switch and if you chose eBay or Amazon make sure it's an OEM switch.
Sent from my SM-G981U1 using Tapatalk
Midnight Storm
Midnight Storm
One Badass Ram
That’s for the reply. Yes the passenger switch has been fully functional.
This morning the master switch is working fine again so at least the window is closed again.
Midnight Storm
Midnight Storm
One Badass Ram
Good to know. Obviously different than my problem of not working up or down but now that it’s magically working again I did that reset anyways. Couldn’t hurt
Fast69Mopar
I disassemble these master switches all the time and I mean fully disassemble them. I clean them with electrical contact cleaner and compressed air to make them fully functional again. Give it a shot. You may be able to keep it working for a long time.
RamCares
n/a
n/a
Any help here?
We certainly understand why this would be concerning. If you are not able to determine a solution based on suggestions from fellow forum members and you decide to address this with your Ram dealer, please be sure to follow up with us via private message. We would be more than willing to escalate your situation to a specialist who can work alongside you and your dealer while your truck is in service.
Kathryn
RamCares
Reticle918
