Fuel gauge stuck on full after pump replacement
Dustyroadz
My idea was unhook the ground to see if it changes, I know on the older stuff, the sending unit was a variable ground, from the gauge, there usally was a ground wire from sending unit to frame of the truck, this was pre electric pumps in gas tanks .
that plug you talk about , just unplug that and see what happens, if you can figure out which wire is the fuel gauge feed, with it unplugged , it likely will read one way and ground that wire it will read the other way. ( to the gauge, not the pump.
But if you have a different reading after the bump, I think your float is stuck, and not moving .
think you have to do it again, pita. if you do pull it check it before reinstalling if you don't see a problem with the movement of the float, pull the relay, so the pump don't run with it out of the tank, and make sure you put it in so the float don't hit the side of the tank.
BTW if you still havn't got it working and lift the box, make damn sure to have lots of good blocking, I know a fellow doing some thing like this with one jackall, and the jack slipped out
His mother found him when he did not come in for supper.
Marshall is VERY correct in the safety department.....Honda Goldwing rider(Atlanta few years ago) died because his bike came off stand and pinned him(he was checking it out for a run to Daytone)his wife came out looking for him :(
W
Wilkechr
Conroe Texas
you probly put the pump in wrong. alot of times thet have a specific orientation. this is why i preach getting service manuals. but nobody ever listens. so they do the job twice
The pump has a tab that can only go in one way
W
Wilkechr
Conroe Texas
You can also download it from the forum. The updated link for the factory service manual is located on the last page of the posting.
None of the service manuals work it just tells me file has been deleted
LoneWolf3574
I have no problem with any of the service manuals. Did you go to the last page (pg4) like I said?
EDIT - Try this link, a new thread was started and it's been a minute since I needed to download a copy.
