Runaround
I have an ‘07 with the crank, no start problem. Tomorrow I’m going to drop the tank to see if I have power at the pump and possibly replace the pump.
Can someone tell me which wire is the 12 volt supply wire and which wire is the ground wire at the plug.
Also are any special tools needed for the pump replacement. I want to have all the tools before I start the project because I’m having to drive about 30 minutes to get from home to the truck.
This again is an ‘07 model that doesn’t use a fuse or relay. It is part of the TIPM.
