Fuel Pump Replacement
jws123
nj
I generally don't say this cause im a cheap FK but use OEM for a fuel pump on these trucks. I used a mid grade after market one wound up replacing year later.
PoMansRam
East Aurora NY
Did you have any symptoms aside from the check engine light?
Is the fuel gauge reading correctly?
EagleChief
Oklahoma
2014 Big Horn
Might look into replacing the evap canister on the tank. It's easy to do. I just replaced mine. Had a check engine light on and check gas cap light. Turns out it was the evap filter/canister thing.
Jeepwalker
WI
2012 Reg Cab, 4x4
Buy the absolute cheapest one you can find on Facebook ...he he
(I say that in jest-but I know people who do ..lol)
Don't forget to check your fuel cap seal...
mdc1990zr1
Conshohocken, PA
I would use oem.
My fuel gauge and sender unit would fluctuate in my 2010 GMC 2500HD to the point it would only work for short periods of time. Rock Auto listed the Delphi as a premium pump/sendor so I got that one. The one that came out was made by Bosch. The GM's of this time were having the same problem with corrosion on the rheostat for the sender. When I got the Delphi unit, it had paperwork saying that there were gold coated terminals and such to prevent terminal corrosion. It looked like a stout replacement, had good lifetime replacement warranty, and Delphi is an OEM producer. I would consider this if availalble.
Goose55
Ajo, AZ
Cummins High Output 6.7L
I have a recall notice from Ram in the incoming mail. Likely the fuel pump replacement recall for my 2019 6.7L Cummins. Service manager told me in Dec the notices would go out 1st quarter of the year, so here it is.
Dusty
Rochester, New York
Like others who have commented, if the lamp is now off, the gauge reads correctly, and you've not encountered any driveability issues, I'd get a second opinion. Have you scanned for any codes?
Regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33 gallon fuel tank, factory dual exhaust, 18” wheels. Build date: 03 June 2018. Now at: 065202 miles.
Freezelagger
3.6 Pentastar
It would be significantly easier to give you some feedback if you would post the code. Huge possibility your fuel pump is not the issue but without sharing exactly what the trouble code was makes every single reply on this thread redundant... this is how bad information gets spread around wasted money spent on throwing unnecessary parts at guessing...
