Gear Oil Question
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
About to take the diff cover off and replace the diff fluid on my dana 44 and 9.25" and ran into a potential issue.
I believe I don't have a limited slip because the dealership told me I didn't and when I burn out in dirt, one tire leaves a big burn out while the one leaves a small burn out. I also lifted the rear, put it in park and spun the tires and they spun in opposite directions. So I think I have an open diff.
But I can only find 75-90w(for the rear) gear oil with limited slip additive. Is it ok to use limited slip oil in an open diff??
Second question: manual says if used for heavy duty or towing applications, use 75-140w instead of 75-90w. I do very little towing of a small trailer and the typical couple hundreds pounds of lumber in the bed often, should I use the 75-140w just because better protection? Or will it just mean worse MPG for me :roflsquared:
BBartow
New Port Richey, Florida
5.9L Magnum
75W-90 is fine. Don't worry about it saying safe for LS, doesn't even have enough additive for them anyway.
I run 75W-140 f/r.
M
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
I run 75W-140 f/r.
Did the 75-140 make any difference in the mpg or us it very minimal and better to have it for the protection?
BBartow
5.9L Magnum
Don't know. I've always used 75W-140 since the front takes it. Rather carry one type of gear oil.
M
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
Went to the dealership and for a 1500 with a Dana 44 in the front, it calls for 4.8 pints of 80-90w of GL-5...
You guys use 75-140 up front?
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
75W140 is what the manual calls for. lol
Service and owners.
1SilverBullet2
North Dakota
2014 Big Horn 8 speed
I use 75w140 up front and 80w90 in the back, never had any issues
