Gear swap
wickedwhite2012
Baton Rouge
Ok I'm ready to throw some gears at this truck. I have a 2012 and I was wondering what the opinions are for a 4.10 gear with some type of limited slip or locker. I have some factory 3.92 but with this one wheel peel it will just blow the tire off. There has to be some type of opinions out there by now.
LovMyRam
Abilene, TX
2013 QCSB Black Edition, 2014 RCSB.
ok i'm ready to throw some gears at this truck. I have a 2012 and i was wondering what the opinions are for a 4.10 gear with some type of limited slip or locker. I have some factory 3.92 but with this one wheel peel it will just blow the tire off. There has to be some type of opinions out there by now.
moes...
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
The factory gears and limited slip unit are still the only option for the 2011-up trucks. If you already have 3.92's, I would just pick up a factory LSD and call it good. The difference between a 3.92 and 4.10 isn't worth the cost of the factory 4.10 gears IMO.
BlownGP
Houston/Baton Rouge
Where in Baton Rouge are you man??.. We need to meet up and race..
I have 4 other RAM friends that meet up from time to time too.
BlkRamRt
SoCal
HEMI 5.7
like matt said not worth it. get a oem lsd and a edge TQ
earlzach
South Jersey
Be certain if you go any change rout you have a good install guy. If done wrong they can be LOUD! Or over heat and ruin everything. Stay with 392 you wont need to do the front just buy the LSD and get it done.
W
wickedwhite2012
Baton Rouge
I don't have the 3.92 in yet. My truck has 3.55 with a open differential. When I put the stall in the tire frying got worst. I want to do 3.92 or 4.10 with a locker or some limited slip. So the only way to go with these truck gear wise is factory?
