gears
bodyman247
wichita ks.
5.7 415 hp
Anyone know who sells 4.56 gears for a 2014 1500 2wd? :) I screwed up and bought dealer stock truck with 3.21 gears.....not good with 20's. This thing at WOT shifts out of first at almost 60 MPH...rediculous....and I have NO low end.
RLJ10X
Southern Indiana
Just click or tap on Moe's above your post. Matt will fix you right up.
loveracing1988
Clarkston, MI
Unless you have a 6 speed your not going 60 mph with a 8 speed in 1st gear. That would be 3rd gear or so.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
4.56's wont bolt right up to your current diff, but we do have a pre machined limited slip unit in stock that is ready to accept an aftermarket 4.56. These are not on the website yet, but give us a call on Monday, and we will get you setup...214-789-1110.
Matt
bodyman247
bodyman247
wichita ks.
5.7 415 hp
it's a 6 speed and yes it shifts into second gear a t w.o.t. at 58 MPH! Thanks,I will give you a call Monday!
Toeknee
will upgrading ur gears void warranty??????? I as well have the 6 speed but with 3.55.......
bodyman247
bodyman247
wichita ks.
5.7 415 hp
I don't know if it will void or not,not really concerened if it does. i may be forced to use 4.10's since no one makes 4.56 yet......
N1ck
Regina Sk
Matt
Will these be for 2wd only? Or '12+ 4wd?
