Hand gun/pistol mounts
wrench78
Air Force Law Enforcement
SE PA
2022 2500 Laramie
6.4L
Hello everyone. I'm a Corrections Officer with my CCW. I'm interested in everyone's ideas on types of car mounts and mounting areas in the truck to have my weapon readily available. Thanks for your help.
nlambert182
Huntsville, AL
I had a stinger mount on the side of the center console, just next to my knee on my 1500. I liked it because it had a trigger guard and was easy to pop in and out. Long distances with a carry on my waist gets uncomfortable because I get sweaty.
Haven't put one in my 2500 yet, but plan to put the same one back in it.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Here's what I did...
StateOfMind
Orange County CA
My SHTF is mounted on back wall of cab, after doing rear seat mod, but it takes me a good 30 seconds to get out, go back, tilt seat and grab, so utterly worthless to you
Only thing better then this is holding it in your hand..
NETim
Nebraska
5.7L
I don't care for off body carry. if you leave the vehicle, it necessitates moving the gun back to your holster which naturally means more gun handling. Anytime a gun is handled the chances for a ND/AD increase.
If you leave the gun in the vehicle, the odds of it being stolen increase.
K2EPM
Long Island, New York
Here we go again.....the best place for your pistol is on your body. This way if you ever get separated from your truck, for whatever reason...the least likely is an ejection....you still have your pistol. But I guess that's the difference with law enforcement and corrections....corrections guys are used to having their firearm locked up while on duty.
wrench78
wrench78
SE PA
2022 2500 Laramie
6.4L
Well when I'm traveling for 3 or more hours in the truck, I rather be comfortable. I'm on the heavier side and sitting puts extra pressure on my side and weapon. On a side note, are you a ham radio operator?
markabby
Monticello, Kentucky
2020 Limited
i have to travel across two state lines, so, i kinda hide mine in case i'm stopped. shhhhhhh!
JW2 Innovations
Supporting Vendor
Sparta, TN
2016 Ram 2500
IWB holster for when I'm going to store, shopping, eating, etc: LINK
Mount for holster to right of right leg: LINK Use this bracket to mount your holster to it: LINK
Console vault for when I need to lock up my "stuff" in center console: LINK I prefer this lock: LINK
Would like to add something like this (with no hinges exposed) at least on drivers rear floorboard side LINK
Docwagon1776
Midwest
Off body carry sucks. I've had more than one case of people shot and killed while trying to get to their off body carry, as in the situations you typically need a pistol quickly you're under observation and unexplained movements get you shot. On person carry still sucks if you're seated, but at least if you get removed from your vehicle you still have it, if you're under direct observation reaching to unclip your seat belt is expected movement, and if you don't have an opening just yet you're still not known to be armed. Additionally, unless you believe yourself to be infallible, more gun handling in an enclosed space where it's difficult to avoid flagging yourself also occasionally leads to new holes in the body you wanted to avoid.
If you need to be comfortable, put it in your purse. If you want to give yourself the best odds of prevailing in the very unlikely event you need it, nut up and carry it on your person.
Dan Topp
Jefferson Wisconsin
IMG_3816.jpegIMG_3814.pngI never let mine leave my side even on long trips but I’ve tried a few newfangled ones that might give you an idea The magnet one isn’t trustworthy enough forIMG_3815.jpeg
chri5k
USA
Diesel
It's a European Man bag and off-body carry. ;-) The lower trim vehicles do have some advantages since you can flip up the center console to give more room on the right side if you are right handed. I get that waist carry can be painfully uncomfortable for larger folks like us. If you are able to reach your ankle fairly easily, an ankle or calf holster provides on-body carry but the draw is not as quick as waist carry. All carry modes have pluses and minuses. Just need to select the best mode for the situation and always practice, practice, practice with a dummy gun for all the modes you might use.
Dan Topp
Jefferson Wisconsin
That’s funny I always thought Fanny packs were girly until I had to carry on long hikes with a lot of gear,bear spray ect. Just the amount of condensation on the firearm made me leave the holster behind.
