Hazardous license plate led's?
Rzrman328
The treeline
I just noticed my license plate lights flash when my hazards are on.
Not a big deal but does yours do this?
huntergreen
Marine Corps Navy Badge
i'll have to check mine, i have no idea if i does this.
Rzrman328
Rzrman328
The treeline
Just in my garage fkn around with stuff. Nothin wrong.
I put led's in my front turns and was checking the brightness in the dark garage with hazards on. Went to the back to check n make sure those were good to go.
My grill led's also flash for hazards which is kinda cool.
Rzrman328
Rzrman328
The treeline
That's weird as ****. I have nothing running to the license plate.
chris1965
South Carolina
If you connected the LED to the signal from the position lights and they flash when hazard light is on, they probably do it also, when you use the turn signal- check it. that'll be the closest possibility. If not- well- that's weird then.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Did you add accessory lights? Sounds like you crossed a wire. Shouldn't harm anything.
Rzrman328
Rzrman328
The treeline
Lightbar and rear pods but nothing even remotely close to the license plate lights.
Like I said...nothing terrible just curious as to if anybody else's did this.
