Headers Maybe? Help me decide!
rduchateau2954
My '11 RCSB 5.7 Outdoorsman has the manifold tick. Only for the first 30 seconds or so but it drives me freaking nuts.
So, a new manifold just seems dumb. Shorties maybe just to make it easy. Or the big dogs. I am leaning towards long tubes but here are my concerns:
I've got about $550 into my exhaust. The outdoorsman had single side exit. I had everything behind the cat lopped off and went carven ar1 into dual 4x16" powdercoated tips at 45 degrees. It sounds awesome, it looks awesome, the welds make me all warm and fuzzy.
If... I go long tube I gotta keep it at the same volume its at now. Any louder and I'm pushing it.
Can I somehow run long tubes with the factory cat?
If not, what volume difference do you think I'd get with no cats but two carven mufflers?
The extra hp, especially with a tune afterwards is really appealing, but I'm not sure if I want to have a 2k exhaust on a truck that sees Wisconsin winters.
Tell me what I should do!
Sent from my AS985 using Tapatalk
Tat2hemi
Rural hall n.c
Long tubes no cats or high flow cats = twice as loud on your current system. I know from experience. I ended up putting a 22" Maggie on mine and it's fine but still wakes the neighbors in the am.
N1ck
Regina Sk
No matter how you do LT's they are going to change the volume of your exhaust.
SlowRoller
Is there something wrong with your manifold?
Typically, the noise you describe is due to broken stud(s),, Replace studs, new gasket, and go,,,
(But you know you want those LT's Heh heh heh!!!)
rduchateau2954
rduchateau2954
It's my understanding the stud broke because the manifold warped.
Hemi8073
Same thing happened to me 2 months ago, manifold warped with the heat and snapped the manifold bolt. Easy fix and is covered by the power train warranty
xrsman
Ontario
3.0 Ecodiesel
You'll still hear the "hemi tick" with headers, actually it'll get louder with them
Sent from my SM-G920W8 using Tapatalk
rduchateau2954
rduchateau2954
Isn't the Hemi tick from inside the motor? I thought Hemi tick was a whole different thing?
Can anyone tell me if there is a way to reuse the factory cat?
Say for instance, headers into a y - cat-muffler-y?
1morepart
2019 Ram 1500 Quad Cab Hemi 3.92’s
Georgia
I have catted lt's and no muffler; however, I would imagine catless would be significantly louder and magnify your "tick". http://youtu.be/L8ylYUpNgkU
joshhhh
